Low compression
zmnewzealand, Sep 18, 10:32am
compression on 3 cylinders within 8 psi dry and same pressure wet then 1 with 30psi less, would you say engines toast? cheers
franc123, Sep 18, 10:44am
What engine are we testing first?
zmnewzealand, Sep 18, 10:58am
mazda z5 had idle mis thought it was ignition related. cheers
phillip.weston, Sep 18, 12:09pm
what is the actual compression readings?
elect70, Sep 18, 12:35pm
Definately needs the head off for 30 psi below . gasket gone or valve burnt .
zmnewzealand, Sep 18, 12:53pm
#1 dry-168 wet-175 . #2 dry-160 wet-175 . #3 dry 162 wet-175 . #4 dry 135 wet- 150. cheers
zmnewzealand, Jun 12, 4:39am
Just kind of did a leakdown test with the compression tester putting 30 psi into the cylinder, can clearly hear leaking from oil filller cap so I guess rings are shot. Cheers
