i think there never is a generic answer to good or bad for anything because good or bad would just mean your a fanboy or a hater .
daryl14,
Feb 23, 7:39am
Ha ha ha. Post of the year mate.
hsvhel,
Feb 23, 7:43am
Good if you drive them on the road, bad if you try to use it as a fishing vessel.
brapbrap8,
Feb 23, 8:08am
Better built but way less power than the Holden Colorado. Not cheap enough though, can have a Mazda BT50 for the same price which is a far better ute.
davidmoore,
Feb 23, 12:19pm
try a BT 50 or Ranger for a comparison as well , then let us know what you think
serf407,
Feb 23, 1:26pm
I think the new D-Max has been uprated to a 3.5 tonne towing capacity. "The four-cylinder 3000 cc 4JJ1-TC iTEQ common-rail diesel engine with VGS Turbo which now has the power of 132 kW with 380Nm of torque." The Isuzu engineers in Japan found 220Kw for a D-Max engine for the Australasian Safari. http://www.ecuchips.co.nz/product-category/cars/cars-isuzu/cars-isuzu-d-max/ The BT50 and Ranger have the 5 cylinder engine that if not quickly refilled with oil at oil changes can cause problems.
Feb 23, 5:21pm
Correct. The same applies to Navaras due to their variable rate oil pumps. Basically, don't let the oil drain interval exceed 10 minutes or as some suggest, replace oil filter first.
Feb 23, 5:25pm
Colorado engine was chipped to get more hp.
Jun 2, 5:14am
Very good, auto nicer to drive.
