I have a 1999 accord cf4. I am trying to plug in a elm327 so I can use the torque app. But where is the port to plug it In?
May 8, 5:16pm
might be obd1 on that japanese where late to implement obd2 , also you know a elm 327 can only read global obd2 codes that are emission related nothing else. i go look i my book where it might be for you now
May 8, 5:20pm
ok 99 accord it is on the left side of middle console where the consol ends forward under th glovebox compartment where these to things join
(PS: thanks for this very useful information - fyi i am a noob :)
pc_uncorrect,
May 9, 3:44am
It's unlikely your Honda is OBDII, most likely OBD-I (old school) as commented above 2-pin & 3-pin diagnostic & service and data-link connectors.
If you check out the Honda forums, perhaps the honda-tech-savy guys out there have developed an diagnostic software (with compatible usb and/or db9, usb to db9 cable to plug into laptop)?
stevexc,
Feb 7, 8:17am
It is ODB2
Sit in the passenger seat and pull the carpet away from the left side of the centre console.
