If my road bike is missing its vin plate can you get a replacement one? from what I can find on the vtnz website it only needs either a vin plate or chasis number which it has so do I need a vin plate put back on.
Feb 10, 3:30pm
Is this the manufacturers VIN plate or an NZTA issued one? If the factory frame number is still there stamped into it then fine if the makers plate happens to be missing, but if NZTA have issued their own 17 digit code to that bike it needs to be present, even though the final digits are the same.
tazcsv,
Feb 10, 6:49pm
It has the numbers stamped into the frame but no plate riveted on. has holes where a plate has been riveted on.
neville48,
Feb 11, 8:51pm
hope its not shady or hot or ?
Feb 12, 11:51am
how many numbers is the chasis number ?
bjmh,
Jun 22, 8:59pm
Mandatory requirements
1. A vehicle first registered or re-registered in New Zealand before 1 April 1994 does not have a VIN or chassis number (Note 1).
2. A vehicle first registered or re-registered in New Zealand from 1 April 1994 does not have a VIN number (Note 1).
3. A VIN number is not valid (Note 2).
Condition
4. A VIN or chassis number has been (Note 1) (Note 3):
a) removed, or
b) erased, or
c) altered, or
d) defaced, or
e) obscured, or
f) destroyed, or
g) obliterated, or
h) affixed unlawfully or by unauthorised persons (Note 3).
Note 1
A vehicle must be referred to a VIN issuing agent (VTNZ, VINZ, NZAA) to have a VIN attached if:
a) the vehicle does not have a VIN or chassis number, or
b) the VIN or chassis number has become illegible.
Note 2
A valid VIN is a unique number that has been assigned to the vehicle in the vehicle??
