Ballpark on left outer tie rod replacment?
ryanm2, Dec 17, 6:55pm
on a 2002 VW Passat B5.5 . Was quoted around the $150, is this correct? Im asking as I have sold the car in question but the price reduced for new owner to get sorted themselves and I dont want to screw them. Thanks.
msigg, Dec 17, 6:58pm
Well that's probably a bit light, if doing yourself then maybe ,add $100 for labour,
ryanm2, Dec 17, 7:14pm
The tie rod (bought of here are only $70 for the pair) would it be done in an hour by a mechanic if it went to plan?
ryanm2, Dec 17, 7:16pm
and are only $18 from this place
http://spare-parts.co.nz/2321-b5-tie-rod-end.html
intrade, Dec 17, 7:20pm
needs a wheel alignement also so 150 would be cheap with part fitted and aligned to spec
ryanm2, Dec 17, 7:24pm
Ok - wheel alignment was never mentioned by mechanic. Learn something new every day dont you.
intrade, Dec 17, 7:29pm
well if they dont the tyre will wear make sure you tell the client that. there is no way you ever get it right when you fit another rod
ryanm2, Jun 3, 1:20pm
Thanks. Appreciate it.
