Trailr safety chains
mk3zephyr, Sep 19, 8:34am
Ok whats the guts on these things, Have a rebuilt 6x4 trailer here( never been rego'ed), Been told the safety chain can be welded to it and then told it cant, Told it has to be bolted to it then told it cant, anyone know what the go is here?
Cheers
gjmman, Sep 19, 8:39am
Sure you will get a knowledgeable answer shortly. But surely you attach with a shackle as thats how it attaches to the car.
mk3zephyr, Sep 19, 8:40am
awwwww so #8 wire or a zip tie wont suffice? hahahahaha
gjmman, Sep 19, 8:57am
A couple zip ties would be stronger than my welding
upnorth, Sep 19, 9:20am
Dog collar and clip-on chain is a fail.
bjmh, Sep 19, 9:30am
5. A safety chain or cable (including any welded joint, securing bolt or shackle):
a) is not securely attached to the drawbar, or
b) is welded to the drawbar, and
i. there is no clear evidence of weld penetration, or
ii. the weld metal has not been applied in accordance with good trade practice, or
iii. there is no evidence that the chain can be welded without reducing its strength, or
iv. the weld is significantly corroded, has deteriorated or is cracked.
c) is significantly corroded, distorted or cracked, or
d) has a bolt or shackle that is missing, significantly corroded, distorted or cracked, or
e) appears to be too weak to withstand a load of about twice the likely maximum laden weight (as far as can be reasonably estimated by the inspector) (Note 3).
bjmh, Sep 19, 9:34am
get a rated safety chain and shackle and bolt it to your drawbar and there is no argument,as it states you can weld it but the inspector can fail it if it looks like a seagull welded it. We used to get caned if a trailer had a shackle on either end ,but if the shackle on the trailer end is secure it should be good.
llortmt, Sep 19, 10:39am
As above bolt it so there can be no argument.
It was changed in the VIRM sometime ago to prohibit welding and then amended to say above re the inspection of weld.
Hence the confusion I think.
lookoutas, Jun 6, 4:07am
You can buy specific chains with a shackle that the pin won't fall out've.
That's so dumb arses can put it through from the left:-)
