Probably worth a bit more if you had another one and a couple of turntables. (o: Always worth something to the right person, but I would say not much. :oP
lookoutas,
Jan 6, 7:14pm
It's virtually a collectors item.
I was lucky enough to visit a man cave over Xmas, and I could see that bit being incorporated into some of the 'car-part' sculptures that are in this cave.
jmma,
Jan 6, 7:17pm
Ooppss, I must be getting old, I used to use those when I was an apprentice Lol (o:
2sheddies,
Jan 6, 7:24pm
Well it's funny you should say that lookout. I seem to remember a neighbour years ago who spied it, going on about how rare it was. but I wasn't so sure. Thanks for the comments so far!
Nah you still a whipper snapper jmma! You defy age just like them Toyota's! ;-P
lookoutas,
Jan 6, 7:39pm
Well it's obsolete then.
jmma,
Jan 6, 7:51pm
:oP
snoopy221,
Jan 6, 8:35pm
lol Mine still has the original box and instructions-And i have the turntables and toe in gauges to go with it and still use them a lot. Reality is that gear is as good as modern in the hands of a competent user. (Apart from doing castor on the rear) And anyone motor racing. And i do recall 3 situations where the road test WAS the deciding factor with modern gear. 1 drop arm fitted upside down changing ackerman toe out on turns not picked up on modern gear 2 crossmember repositioning required to even camber 3 employee fired left magnet on machine Personaly i'd value it between fiddy and 2 spot-The market will decide.
2sheddies,
Jan 6, 9:46pm
Thanks heaps guys!
thaiweebabe,
Jan 8, 5:10am
How do you use the Trademe photo server?
2sheddies,
Mar 12, 8:12pm
What I do is this.
I open TM in two separate tabs. Have your photo ready in a convenient folder. In the first tab, go to 'My Trademe'. Select 'My Photos'. Click 'Upload Photo. Click choose, find the folder/photo and select it. Then once it's uploaded, return to your main photo page, where you can then select and open the image. Then right click the address bar at the top and select 'copy'. Now move to the second tab, where you can have the message board page waiting. Right click in the message box and select 'paste'. The link to your image should appear.
Hope that makes sense and helps!
