Au fairlane locked keys in side
neldo8, May 18, 7:29pm
Can door be opened with a coat hanger
saxman99, May 18, 7:32pm
Probably. The back door might be easier.
monaro17, May 18, 7:33pm
Au. not 100% sure but probably no
neldo8, May 18, 7:43pm
Iv had a go but no luck opened a xh with one a while back
serf407, May 18, 7:48pm
The standard answer is 'Call the aa or a locksmith etc.' without divulging methods of accessing cars etc.
2sheddies, May 18, 7:54pm
Not as easy as older cars that's for sure. Might be easier and less hassle to get a lockie. One thing that can happen while fishing around in there is to snag and dislodge one of the handle linkages instead of the lock one. Then you've just made things way more difficult for yourself.
bashfulbro, May 19, 4:27am
Get the flat ,plastic tying stuff, that they wrap around packaging, that should do the trick better than a coat hanger.
whqqsh, May 19, 6:04am
don't think the plastic will work, from memory my AU button pushed flush with the door card
goldilocks64, May 19, 7:09am
call the AA if your not a member they can join you up or get you some assistance at your cost
neldo8, May 19, 7:10am
Yes button is flush and only the drivers door has one
gmphil, May 19, 8:39am
rear window big rock ! it only an au wots a rear window worth 20 buks in half hour u time put new one in cheaper than lock smith !
ntalke, May 19, 8:55am
AA have a plastic card that is inserted between body and door,this is then pumped up expanding the gap allowing for a wire or coat hanger to manipulate the door opener
Had this happen as locked the keys in the Boot
bigfatmat1, May 19, 11:01am
You need to wedge door out and pull drivers door handle with a piece of strong wire. If it's deadlocked the lock will need to be picked
bjmh, May 19, 11:53am
my old man locked his keys in his new HT ute . way back. a cop came along and asked if my Dad wanted assistance. yep says my Dad.Cop pulls a wooden truncheon out of his pocket,smashes the 1/4 glass and walks off.
jetsin5, May 19, 12:28pm
wedge the top of the door open and get a piece of wire in there and open the drivers Inside door handle, it is quite easy and unlocks the whole car
neldo8, May 19, 12:49pm
Yea mite smash a window . like the cop story lucky they didn't truncheon his head lol did your old man wear a black jersey
intrade, May 19, 12:53pm
it was 180 bux for the triangular window secoundhand on my hilux because every thaive brakes that one means the prices are high and hot for these items . so i dont advise you smash any window what so ever,
intrade, May 19, 12:56pm
my dumb qestion is where is your spear key you cant tell me you only have one key. or you better get a secound key made while the locksmith comes out.
neldo8, May 19, 1:35pm
Only came with one key but yea two keys for every thing from now on
elect70, May 19, 1:50pm
The top corner by the pillar is best way to get a wire in hook the door handle & pull . Did it on VL commie , easy as .
dingo011, May 19, 1:54pm
I had this happen to me when I left my dog in the car and ran into a dairy. The dog saw me coming back, jumped up and pushed the drivers door button down! Had to call the AA. Long piece of wire with the end bent to a right angle and the tip ground to a sharp point. threaded down from the top of the door, got the point down between the button and the surround and pulled it up. He made it look easy!
gmphil, May 19, 2:18pm
yup sum can be but in this case ul get a window from pick part or trademe
jmma, May 19, 2:41pm
May as well tell OP how to hot wire a car as well, but then I guess you don't know who is reading the MB
budgel, May 19, 3:30pm
Can modern cars be hotwired?
bigfatmat1, May 19, 4:16pm
Ok the easiest way is to wire a module that you buy of the net connect to pin 4 of the ecu as well as batt and earth. then pick the ignition barrel with a special tib lock pick set Actually a relatively hard vehicle to get going with no keys. without the correct equipment. This information is freely available on the net. But google does not search tm mb
