Looking at replacing scissor jack
inkapuka, Feb 19, 7:13pm
whats better/easier than this thing. Really takes a long time to lift the car up and is hard on your knuckels must be able to fit in back of car and under car its quite low also
inkapuka, Feb 19, 8:21pm
Thats wayyy too big man neds to be smaller than one of them
muzz67, Feb 20, 4:08am
Trouble with sissor jacks is that at the lowest height, they have very little leverage,, but as they get higher they work better and better.
Just use two, one on each side if you need to lift two wheels up.
bill-robinson, Feb 20, 4:43am
long pole and a block of wood would be easiest. still to hard,get a longer pole. not high enough, get a bigger block.
m16d, Feb 20, 3:16pm
inkapuka, Feb 20, 4:02pm
As above a trolly jack is not what i am looking for im awanting something better than cars jack that has to fit in behing fabric pannel on the side in boot
holdensorfords, Feb 20, 4:08pm
Get rid of the winder by welding a 3/4 drive socket on it & use the ratchet to wind it up/down with extension.
sr2, Feb 20, 5:14pm
Weld a nut onto the jack and use a cordless drill, works a treat!
Buy a cheap 2nd hand one with a stuffed battery and convert it to be powered from the cigarette lighter socket.
Otherwise buy one of these.
http://www.ebay.co.uk/itm/12v-2-Tonne-Electric-Car-Lift-Scissor-Jack-Carry-Case-Cigarette-Plug-/281493390196
inkapuka, Feb 20, 5:44pm
That is cool and fine and dandy but welding a nut on sounds so much easier and better lol thanks might do that tomorrow
gpg58, Feb 20, 5:50pm
Supercheap and the like sell geared versions of scissor jack, so much easier to wind, but slower still i quess, but then again maybe quicker as you can wind fast, anyone tried them?
sr2, Feb 20, 5:56pm
Forgot to mention in my previous post that a hydraulic scissor jack is a good option as well.
http://www.palmside.co.nz/product_pcid_15517.html
gmphil, Jun 7, 10:05am
air bag jack ?
