Blocked grease nipple
jh34, Jul 18, 10:13pm
If I take a grease nipple off my old trailer is a new one likely to have the same thread?
toyboy3, Jul 18, 10:16pm
Take the clear nipple off the other side and change it over and see if the nipple is blocked first
gpg58, Jul 18, 10:20pm
depends how old probably, could be metric(various pitches) or imperial thread(bsf,bsp,unf,npt), along with different diameters.
Best take sample with you.
ceebee2, Jul 19, 2:33am
One is course thread the other is fine. simple for most applications.
dublo, Nov 21, 1:50am
First check to see if it can be unblocked! Remove it from the hub, mount it in the vice (not against the thread, hold it with the jaws against two of the hexagon flats!) and try pumping grease through. Chances are that will clear it.
