1985 2ltr. replaced distributor pick up coil and now I cant remember what wire goes where. Have one blue and one black with white stripe from distributor and one black with white stripe and one black with red stripe coming from the loom. would appreciate any help, thanks.
rob_man,
Oct 21, 9:14pm
Feed in on the positive side of the coil and out on the negative from memory. The wires from the loom are probably the live ones so should be to the + side. One will be the ballasted and the other unballasted for starting. Two from the dizzy I'm not too sure about, yours will no doubt be breakerless.
