Hello, I have a 05 Honda Odyssey and recently having some problems with the Navi/radio system. Obviously, the system is in Japanese and the satnav doesn't work but the radio always worked. Few months ago when I start the car the screen keeps trying to reboot. I see the Honda entertainment screen then it reboots itself several times, sometimes taking up to 10 minutes. While this is happening I can still listen to the radio by turning the volume up but no screen as it is keep rebooting/loading. Bigger problem is when in reverse. Most times the reversing camera shows on screen but sometimes the screen suddenly turns black. Would anyone know what the problem is? Would it be a problem with the whole unit or just some wiring?
gammelvind,
Aug 22, 5:17am
Go to JB hifi, buy new NZ unit, install. Problem solved.
tlng,
Aug 22, 7:57am
13 years is a pretty good run for a radio system these days. I'd look at hyper tyres for a new stereo. Pretty good deals there.
Aug 22, 7:34pm
If its the integrated hionda unit then I would say the unit itself is goneburgered. BUT try running a disk clean in it in case the laser itself is dirty.
trade4us2,
Oct 19, 9:00pm
If you examine the circuit board with a magnifying glass you may find a cracked solder joint, particularly in the earth connection.
