L200 coil wireing help please
oldgezza, Aug 21, 12:45am
1985 2ltr. replaced distributor pick up coil and now I cant remember what wire goes where. Have one blue and one black with white stripe from distributor and one black with white stripe and one black with red stripe coming from the loom. would appreciate any help, thanks.
snoopy221, Aug 21, 1:51am
Been to damn long to remember.
However 2 of your wires from the distributor go to the coil positive and negative.
And the 2 loom wires will possibly both go to the coil positive -easy way to check these is one will have power with the ignition on and the other will have power when the engine is being cranked by the starter motor.[6volt coil with ballast resistor and 12 volt feed when cranking]
If there is a rev counter in the dash and power is not as described then one of the loom wires may be a negative coil rev counter pick up.
Suggest ring one of ya local auto sparkies or mitsy dealer to confirm which wire [blue or black white stripe is coil positive from distributor-been too many years lol]
Hope This Helps
snoopy221, Aug 21, 1:59am
From here suggests blue negative coil and black white positive coil.
However as above would double check with an auto sparky
http://datsun1200.com/modules/mediawiki/index.php?title=EI_Wiring
Overview
Connect them as follows:
Black/White wire to 12V ignition circuit -- the POSITIVE coil connector for an EI Coil. Or the POSITIVE side of the ballast resistor if you haven't got the EI coil yet. The distributor control unit needs a full 12V
Blue wire to NEGATIVE coil connector
oldgezza, Aug 21, 2:00am
Thanks for that, I can confirm that the loom black with white stripe is power, no rev counter, just don't know what is power from distributor. Yeah its too old for most to remember.
oldgezza, Aug 21, 2:08am
Thanks , sorry , its a Mitsi L200 4g63 and just standard coil with no attached resistor as seen on later utes with the 2.6 motor.
snoopy221, Oct 22, 12:01am
bigfatmatt may pop in he will know for sure although #3 and the memory sort of align but either way they go where ya removed em from-LOL
Next time use ya phone or digital camera to take some photos . LOL
Edits to add eighties and electronic ignition be pretty damn sure it is a ballasted system.
Simply use a test light and check for power with engine cranking.
