YEEHAA common sense prevails.
kazbanz, Jul 19, 12:04am
After a lot of faffing around it seems that sections of the Auckland motorway currently 80km/h will revert to 100km/h. The sections around the waterview tunnel will be 100km/h -except the tunnel itself.
fatrav, Jul 19, 12:28am
Its just called sense these days. it aint common.
cjohnw, Jul 19, 12:56am
Took them blimmin long enough.
I am ALWAYS overtaken when I stick to the limit doing 80kmph approaching the tunnels.
sw20, Jul 19, 1:59am
Common sense is a myth.
budgel, Jul 19, 3:00am
A myth is an effeminate moth!
trogedon, Jul 19, 7:55am
There is no good reason to increase it from 80.
headcat, Jul 19, 7:59am
Well now you might be able to do 10 kph
msigg, Jul 19, 5:08pm
It just means more tickets for those entering the tunnel over speed and more hitting the anchors just before the tunnel causing more problems .
kazbanz, Jul 19, 5:36pm
what about the 27km of motorway that has in real terms nothing to do with the tunnel? -SH16 to town and back from rosebank and all the rest of the motorway leaving the tunnels? --ie from a km beyond?
peja, Jul 20, 12:03am
Good. Not before time. If I do 90 there I am overtaken by everything including some trucks
trogedon, Jul 20, 6:12am
If the speed limit is 100 and you do 100 you'll still be overtaken by speeders. Most of the time there is a lot of traffic on that section of motorway.
kazbanz, Nov 18, 11:51pm
looks like from Monday the section of 16 from Rosebank to springs offramp is 100 in offpeak Spagetti to rosebank. from tunnel exit southbound and the 100 extends to past Moire rd heading into the tunnel.
Then the next bit will be st lukes into spaghetti
