Can anyone shed any light on why the fitting in the video is leaking ? I see there is a tiny hole but there in all the fittings and this the only one leaking. Could this just be a dud ? https://www.youtube.com/watch?v=bJDbQDIcZtw
mrcat1,
Oct 8, 11:24pm
Either it is loose and needs tightening, or by going by the look of the nut it's been cranked up too tight and it's split the seat in the fitting and thats where its leaking. I have used hydraulic fittings like that and they won't handle being over tightened, they are a spun fitting rather than a machined one which seems to handle having their necks rung a bit better.
Oct 8, 11:36pm
a dud or did you put it in the wrong direction?
kinger7,
Oct 8, 11:38pm
Wrong direction ? ill pull the fitting of and investigate . Does anyone know what that little hole is for ?
mrcat1,
Oct 8, 11:44pm
It will have a pin in it to hold the fitting together, I'd say you have over tightened it and split the seat and when they leak it comes out thru there as it cant come out past the thread.
kinger7,
Oct 9, 12:58am
Well you were all wrong . . . it was the complete opposite , wasn't tightened . All sorted, sitting 85 psi and holding pressure
joanie04,
Oct 9, 1:29am
Check post #2 again, that is the first thing mrcat1 said.
skull,
Oct 9, 3:03am
Anyone that goes to the trouble of creating a video and coming on here without first checking if the coupling is tight has to be wronger than any of the posters on here.
mechnificent,
Oct 9, 3:12am
Ha. That is pretty funny.
We should never underestimate.
Good for you Kinger for coming back in and fessing up.
kinger7,
Oct 11, 10:12am
lol is what it is. I was damn sure everything had been tightened but hey, ya win some ya lose some
mechnificent,
Dec 27, 4:40pm
Good man.
