2006 ssangyong musso
bjmh, Sep 12, 2:46am
anyone with a link to a serpentine belt diagram for this vehicle 2.9 diesel
intrade, Sep 12, 4:36am
yea rebo.eu.
try doing it on a mb140 same engine with the radiator and shraud in.
korando has the same engine .
on top use a pipe in to the hole and take the tension off and slide a pin in while you put the belt on. i got it on with logic thinking its quite a maze as the one belt goes everywhere . haha
intrade, Sep 12, 4:50am
also be warned its a special belt it runs on both sides i fitted a new belt from saco wilson and then the wof guy told me the belt was no good i said i fiotted a new one 3 weeks ago. after 2 month i hat stuff comming off the belt and then i realised that the belt i fitted was cotton on one side it needs to have abracive resitante surface on both side. So i had to refit the old belt again took me 45 minutes in the 2 inch gap and leaning from inside over the engine to pull the tensioner and slide the pin in while the tensioner wanted to snap back again.
should be a walk in the park on a musso.
cant find a diagramm in the notes on rexbo but trz if that is it
http://www.fixya.com/fullimage.html?src=http://i.fixya.net/uploads/images/11_26_2012_1_27_24_pm.jpg
my one has no AC but you can see how the belt runs on both the sides
intrade, Sep 12, 5:48am
stick a pipe in there to get tension off got to unbolt the bolt . then release tension.
https://i.ytimg.com/vi/DCKMI8SVRYs/maxresdefault.jpg
you should know what i mean when you look at it! routing remember runs on both sides.
intrade, Sep 12, 6:29am
bjmh, Sep 27, 1:18am
cheers intrade I eventually sorted
