hi all ive got a nissan navara 85 but i have no lights on my dash checked fuses in cab and all seem good where do i look or what do i do now thanks in advance
thejazzpianoma,
Sep 1, 7:59pm
Does the truck otherwise start and run? When you say "no lights" do you mean no lights at all or just no gauge illumination?
gumboots70,
Sep 1, 8:01pm
it ran 2 days ago but i have no lights on the dash so iam quessing no glow to plugs that why it just turns over and over
Sep 1, 8:04pm
heve you tride the adjuster nob ?
gumboots70,
Sep 1, 8:11pm
its not getting fuel or glow to plugs it doesnt run a ecu so what gives these old motors main power ?
Sep 1, 8:17pm
Ang on- yer dash lites not going iaint the same thing as not running, if itz a diesel then ya need to double or triple glow it by now.
gumboots70,
Sep 1, 8:37pm
tried different battery jump starting no fuel coming through line there is fuel when using manual pump no dash lights at all but does wind over [the motor] no power to glow plugs either but have main head lights and tail horn etc cant find main fuse [ie] big sucker like most cars have , no ecu [so not that] lol
tweake,
Sep 1, 8:51pm
there is typically fuses and relays under the bonnet somewhere. quite likely one has failed.
snoopy221,
Sep 1, 9:10pm
Yarr be the long cable fuse (as in fusible link) on the battery positive
gumboots70,
Sep 1, 9:22pm
yeah sounds like a multi meter job pitty i dont have one [bugger]
shakespeare6,
Sep 2, 2:21am
As above there is a couple of fixable links on the battery positive lead 2 could be 3 from memory. Not much else other than a couple glow relays under the bonnet - pretty basic
ozz1,
Sep 2, 4:44am
go buy one
thejazzpianoma,
Oct 10, 12:52pm
This! Also a test light.
