Pre purchase inspections
oldboyjohn, Sep 20, 9:26pm
You could try the AA, or VTNZ. Or better still, take it tho the garage where you get your servicing done
kazbanz, Sep 20, 10:17pm
in my opinion you are best served using Car inspection services or your own Garage.
That said there is a LOT of information you can gather for free before paying for an inspection. ESPECIALLY if the car is a fresh import from overseas.
intrade, Sep 21, 7:23am
id say he would be one of the best if not The best for inspection
https://www.incarautomotive.co.nz/
beno, Sep 23, 1:42am
not a good advert for car inspection services
http://www.nzlii.org/nz/cases/NZMVDT/2017/114.html
smoothgroove, Sep 24, 3:40am
I used to go with Car Inspection Services because they have saved me $$$ on detecting faults, even with vehicles off the dealership with brand new WOFs (somehow 2 leaking shocks passed a WOF). They were also one of the few that did manual compression tests (if you want that done). But my last experience with them was less convincing. They managed to complete a full inspection with compression check, on a boxer motor, with the vehicle parked on a slanted driveway, within about 20 minutes. This was performed in my absence (owner was present).
I've had AA miss a faulty centre diff on a vehicle with which this was a known common fault.
So I think no one is 100% and there will be differing opinions between different inspectors.
tgray, Sep 24, 4:00am
If you want comments like "stiff rear vision mirror" as a potential warning, then the AA are your guys. (actual wording on AA report to customer).
thejazzpianoma, Jan 11, 11:50pm
You forgot the part where they simultaneously ignore or don't check for serious model specific faults.
