SLK 230 Merc
bretals, Jul 11, 4:04am
I have a 2290cc supercharged Mercedes and want to get more power. what would the best way to go. Standard SLK230 give 194hp. Be good to get another 20 to 40hp
desmodave, Jul 11, 4:08am
https://www.slkworld.com/performance-mods-r170/3010-simple-slk-230-mods.html
Have a read up on what others have already done .
timmo1, Jul 11, 4:33am
Smaller S/C pulley or larger crank pulley + possibly a rising rate fuel reg I would've thought
poppy62, Jul 11, 5:32am
elect70, Jul 12, 12:16am
Put the 320 V6 in good for 160 Kw standard . 4 bangers regarded as hairdressers cars & s chargers wont like spinning any faster . they already renown for doing in the bearings @$$.
bretals, Jul 12, 4:22am
I thought about that but it's only a gain of 21hp plus the extra weight I didn't think that was worth the effort.(only half a second quicker 0-100km)
SLK230
Kompressor 1996–2000 M111.973
2.3 L I4 supercharged 142 kW (190 hp)
@ 5,300 rpm 280 Nâ‹…m (207 lbâ‹…ft)
@ 2,500–4,800 rpm 7.4 s
2000–2004 M111.983
2.3 L I4 supercharged 145 kW (194 hp)
@ 5,500 rpm 280 Nâ‹…m (207 lbâ‹…ft)
@ 2,500 rpm 7.2 s
SLK320 2000–2004 M112 E32
3.2 L V6 160 kW (215 hp)
@ 5,700 rpm 310 Nâ‹…m (229 lbâ‹…ft)
@ 3,000–4,600 rpm 6.9 s
sw20, Jul 12, 8:58pm
Want more performance? Buy an actual fast car to begin with.
elect70, Jul 13, 12:27am
Hp isnt everything V6 lot more torque & a much nicer motor very smoooth 7 reliable . but probably not worth the cost . Sell it & buy a real SLk a 500 SOC around late 80s the later DOC actually have less power due to more anti polution crap in them
headcat, Jul 13, 4:58am
You can almost guarantee that you will remove any cost of "improvements" from the value of the car. I know that any meddled with car will be instantly deleted from my watch list.
meow_mix, Jul 13, 5:20am
A supercharged SLK230 should be a reasonably fast car when standard. I wouldn't transplant a V6 into it, you will just be opening a can of worms, far better ways to spend the money, for instance if the standard supercharger won't take any more speed then upgrade it to an aftermarket one. That, and the good ol' big exhaust and upgraded air filter (not a pod, they're more trouble than they're worth).
intrade, Nov 27, 7:56pm
Thats not always the case at least its not the 1.8 hand granade.
for vw the 1,9 unit injector you can get emense monster tuning up to 600hp from its original 150 with special injectors and monsta turbos because they are built rugged for racing from the factory. vw rooted the transmissions in 1996 on there race tdi hence why my vw has the rugged 6 speed powertrain beefed up and taken from the vr6.
