Where would i find an early model holden rim 5 stud to fit 13 x 155 tyre.I think HJ or around that era.
donz01,
Aug 11, 10:41pm
I am pretty sure that 5 stud 13 inch rims were on very early holdens from around 1957 FE ? through to about 1977 on LH and LX Toranas. 1969-1971 models had the same stud pattern but were 14 inch. Even early 4 cylinder VB, VC, VH and VK commodores had 13 inch rims that did fit 1958 FB thru to 1977 Toranas . Basic models with 13 inch rims are FB,FC,EK,EJ,EH,HD,HR then the Commodores andToranas as listed above. HJ era were all 14 inch and a different stud pattern to early holden 13 inch rims. Hope this helps
Aug 11, 10:51pm
horopito motors might have one.
newtec1,
Aug 12, 12:12am
Cheers for that
mecanix,
Aug 12, 2:44am
Aging auto spares.
Or.
Neil
At eden park car spares.
09 846 4856.
I would probably try him first.
lookoutas,
Aug 12, 3:59am
Where?
atom.ant,
Aug 12, 5:55am
yep as above said but the lc,lj,lx,lh and uc were all 13" as well the commodore are 6" (v's 5.5") wide though so they might not take a 155 tyre
atom.ant,
Aug 12, 5:58am
also the ht,hg holdens had the same stud pattern but were 14"
newtec1,
Aug 12, 7:47am
I thought they closed down years ago, or have they moved ?
newtec1,
Aug 12, 7:48am
That's interesting, it might be easier to find 14 in
edangus,
Aug 12, 8:49am
Standard LJ Rim is 4.5JJ. GTR is 5.5JJ. Original Tyres are a A78L13. Which equates to around a 175/80/13. I run 185/70/13 on my standard rims. Which is within tolerance. Almost to wide for a 4.5JJ. Run 195/60/14 on my period mags (HT) which I think are 5.5JJ. Would have to check if a 4.5JJ would take a 155 nicely.
Edit to add. A 155 will fit. It's the lowest you can go on a 5". I think I saw some advertised this week. LJ Rims
mecanix,
Aug 13, 10:32pm
Ageing. They are on spartan ave.
Eden park car spares are on the corner of sandringham and royal terrace.
There is a real estate agent there now as well.
sr2,
Aug 14, 3:38am
We can probably tell you what model/s the rim you're after if we know the PCD. On a five stud, measure the distance between the outsides of two adjacent studs, subtract one stud diameter and divide by 0.58778.
gpg58,
Aug 14, 4:40am
Probably not your cheapest option being down here, but Mc wheels in Canterbury(kaiapoi) may be able to help if no luck closer. http://www.mcwheels.co.nz/contact.php
seadubya,
Aug 14, 5:29am
I'm pretty sure they are 5x108mm or 5x4¼".
sr2,
Aug 14, 8:13pm
At 5 x 4 1/4" In 13 inch you're looking at LC, LJ, LX, or LH Torana.
If it's presumably for a trailer you might find it easier to find a pair of 14 inch HK to HG wheels and tyres (same stud pattern).
seadubya,
Aug 14, 8:27pm
Don’t forget the Starfire Commodores. Four cylinders of excellence that happened to run 13†wheels.
sr2,
Oct 27, 8:53am
Yes they had the same stud pattern but had 12 mm not 7/16" studs.
