Allen key
gzee, Nov 26, 4:09am
would any one have a 19mm allen key for sale?
intrade, Nov 26, 4:12am
what do you need it for? oil sump plug?
tony9, Nov 26, 4:14am
intrade, Nov 26, 4:16am
just looked my large one is 17mm "L" shape key
budgel, Nov 26, 5:05am
When I got caught short on that I got a 19mm bolt and wound two nuts tight on it. It worked!
marte, Nov 26, 5:55am
3/4 inch = 19.05mm
Or #5, bolt & 2 nuts.
It tends to snap the tip off the screwdriver off if you use a smaller Allen key & a screwdriver tip jammed in there, but sometimes it works.
cabrio1, Nov 26, 7:06am
I've done that, worked well
intrade, Oct 20, 3:08am
you obviously work on toys . i used a meter extension bar on a ellen key that size and it would still not open.
