Where can i buy
elect70, Aug 30, 5:12am
Plastigauge im doing up a motor & want to check the crank journals for wear
skull, Aug 30, 5:14am
gunhand, Aug 30, 5:21am
Repco has it, well they did 12 years ago.
tweake, Aug 30, 5:23am
RS products are not typically stocked locally and air freight is all over the show at the mo.
intrade, Aug 30, 6:35pm
morrisman1, Aug 30, 6:55pm
last time I bought some it was from the local engine rebuilding shop.
skull, Aug 30, 7:19pm
100% incorrect, if you bothered to check the link I gave for NZ stock there are 6x boxes of 10 available for delivery in 1 business day.
franc123, Aug 30, 7:38pm
Checking them with a micrometer is a better idea. Plastigauge only tells you what the clearance is, not if the journal diameter is still within spec or not, or requires machining.
elect70, Nov 28, 7:13pm
dont need it now wrong shells supplied
