How are all the EV's going to get Charged
Page 1 / 3
loud_37, May 3, 4:21am
Blackouts and Brownout are possible this year, what will happen when more EV's are being used.
tygertung, May 3, 4:29am
More generation?
loud_37, May 3, 4:33am
How long is that going to take 20 - 50 years?
remmers, May 3, 4:37am
In the process of getting 16 panels installed this month, neighbour has just had similar installation completed, 42.4c /kWh here in Northland!
harm_less, May 3, 4:39am
In our case a few weeks hopefully. We've got 5kW of solar in the process of being installed. No storage planned in our installation but at least we're taking ownership of a good portion of our consumption including EV charging.
And for those bleating about EVs I trust you've turned your spa pools off by now.
stevo2, May 3, 4:54am
Depends if Tiwai actually closes at the end of 2024? If so, there'll be more electricity produced than we can actually use, so some of the grubbier ones will be shutdown.
intrade, May 3, 5:59am
The R-- tards are also pumping out news that they will make your lpg in to hidrogen. I guess they never did hear of hydrogen explotions. You really wonder if they have 1 single brain cell.
yea you really want hydrogen to cook with instead of the saver LPG we already have.
https://en.wikipedia.org/wiki/LZ_129_Hindenburg
apollo11, May 3, 6:04am
I don't like hydrogen either, but bigger brains than yours are working on it, so don't let it worry you.
tygertung, May 3, 6:13am
How about a wind turbine?
apollo11, May 3, 6:31am
All right, I'll take it.
harm_less, May 3, 6:56am
The (lifetime) costings on smaller (domestic) turbines aren't even close to those of PV. NZ's typically gusty wind conditions tend to destroy the mechanicals and very few locations have consistent wind run thereby meaning turbines spend a lot of time as ornaments. Even in a prime location they come close to payback about the same time major repairs are required. You're actually better off investing in a micro-hydro system if you have a stream with consistent flow handy.
tygertung, May 3, 7:24am
What if the government puts in a wind turbine, like they do in Germany? I was there in about 2012 and they had loads.
gph1961, May 3, 4:21pm
hang on a mo Ill just recheck the backyard
nope,cant see/hear any running water
strobo, May 3, 5:15pm
apollo11, May 3, 7:35pm
Wind turbines will be an enormous waste issue when they reach the end of their life spans.
https://www.youtube.com/watch?v=NlK5er8XxiI
bitsy_boffin, May 3, 8:04pm
socram, May 3, 8:22pm
Solar energy has to be the way forward. Looking out the window right now, hardly any houses have solar panels.
My brother (a licenced photo-voltaic installer) fitted panels to his partner's small house in the UK, and even in a UK February, there is some gain.
The problem in NZ will be the rip off power companies making sure that no matter how much or how little power you generate for yourself, they'll still be charging an arm and a leg to maintain their profits.
No doubt many will have seen the pic of the helicopter emptying a bucket of de-icer on just one frozen wind turbine.
gazzat22, May 3, 8:25pm
I,ve done my sums several times and even if Electricity increases in cost by about 200% at least theres no benefit to me:my heirs and successors maybe.!
harm_less, May 3, 11:56pm
The key to maximising PV returns, and therefore ROI is to use (or store) your own generation. Storage can be as simple as diverting 'excess' generation to heat a HWC or charging an EV as by doing so you are offsetting consumption that would otherwise cost you full retail including GST so that is your effective return on that electricity.
tygertung, May 4, 12:07am
Surely no more than any other power plant?
kiwilandchch, May 4, 1:40am
higher power prices with the excuse to try make people travel less to save power
likit, May 4, 1:48am
No problem, burn more coal.
apollo11, May 4, 1:57am
The fibreglass/carbon blades are an issue. They are truly massive things. I wonder if they could use pyrolysis to remove the resins and recycle the glass and carbon? If other forms of energy generation are an end-of-life issue then they need to be examined too. Although I suspect they would be mostly metals and concrete, all of which are recyclable.
tygertung, May 4, 2:14am
Could just make them from aluminium, same as an aircraft. Construction is easy enough, just press out the frames and rivet the skin on. Pretty mature building technique. Aluminium can very easily be recycled.
However the blades may be able to re-used, just rebuild the generator unit.
apollo11, May 4, 2:30am
I suspect stress fractures might be the reason why they don't use aluminium. Aircraft wings get regular inspections for this reason.
