1995 d21 datsun gurus out there?
b00f01, Dec 28, 3:25am
Hi there just wondering if anyone knows how to go about converting a column change manual ute (2wd) to a floor change. Is it only a matter of getting floor change assembly or does the whole box have to come out and major parts swapped over
tweake, Dec 28, 3:34am
i don't know nissan but have dealt with toyotas and they have a different gear box. you can easily tell by looking underneath to see where the control rods go to on the gearbox, ie to the side of the gearbox or on top.
b00f01, Dec 28, 3:38am
So if they are on top floor change would be an easier conversion if not the end of the box would have to be swapped out?
tweake, Dec 28, 3:50am
i don't have the book on the D21, just looking at the early d22 (no column change).
its possible to change the rear half of the gearbox over, assuming its the same model gearbox. but thats a fair bit of work. a whole lot easier just to swap a whole gearbox over. especially as you need a donor gearbox/ute to get parts from any way.
b00f01, Dec 28, 3:57am
Cheers for the info
supernova2, Oct 5, 10:06am
what engines in it. my factory manual only shows a floor shift
