Why? 2020 by and large most are slow like cheap vacuum cleaner cords having the need to jiggle some to get them to fully return!.ok some have some dust build up ,or drag a little thru the guides or where they are inbuilt to the seats drag thru seat cover slots but they never seem sprung enough.
poppy62,
Jul 14, 2:13am
You can wind up the tension on the spring.
gph1961,
Jul 14, 4:28am
sounds like a windup
wind.turbine,
Jul 14, 7:47am
actually your not wrong, and my pet hate is when the mrs gets out and leaves a small twist in the belt and it cannot overcome that when winding up, it then ends up jammed in the door.
strobo,
Jul 14, 8:04pm
Have you done this? i dont believe ya can tamper with seat belts ,just saying ,its a savety device.Even seat belt re webbing people have to supply a cert for alterations.No not a wind up #3 ;-) .im blardy serious .
poppy62,
Jul 14, 8:42pm
Yes! on the spring side undo the 2 small screws on the cover keep pressure on the cover otherwise the spring will fly out. Then wind the cover anti clock wise 3-4 times replace the screws and the tension should have increased markedly.
strobo,
Jul 14, 8:46pm
The seat belt retractor ya talking about not a briggs and stratton pull start ! Anyways I 1/2 believe you ;-) They look preety much sealed up !will have a look later.shouldn't need to do this though ya know .
Jul 14, 9:18pm
you got to give more details if ity like my 96 punto you could wind the spring. However if it has a airbag and potentially a seatbelt pretensioner you cant temper with it as it is way more complex and dangerous overall then old simple seatbelt.
poppy62,
Jul 14, 10:06pm
Found this as an example worth a watch: mostly from 4 minutes on.
https://www.holdspares.com.au/commodore-vt-vu-vx-vy-vz-right-front-safety-seat-b Is a clip in cover ,lifting it will probably unspring it ? lugged in clips on the cover that come some ways out if released , too dodgy looking to muck with me thinks .looks factory assembled ,Yeah if it had screws i'd be into it.Holden vy
strobo,
Jul 14, 11:56pm
Maybe that euro stuff aint that bad after all ! Your punto kamikaze machine probably doesn't even need a seat belt ;-)
sweetgurl108,
Jul 15, 7:20am
thx
Dec 24, 9:47pm
with the new stuff you don’t wanna try that
