Immobiliser
titoki, Jul 31, 4:41am
i havent stolen the vehicle, but I want to remove the immobiliser, it's aftermarket one.
it is a pain to use, and both fobs are broken.
anyone have good youtube link, or better still a reliable place in christchurch to do it.
1997 escudo
intrade, Jul 31, 4:56am
easy enough aftermarket garbage will just be hacked in to the wiring harness, i think zephire heaven is in chch
otherwise that company can do it or knows somone reliable
http://www.getelectronic.co.nz/
you need to remove and rejoin the wiring harness correctly again best done if you have soldering tools crimpers and shrink tube and a bit of knowhow otherwise you better let professionals do it as its going to cost more if you f---k with it first.
sw20, Jul 31, 6:29am
Zeph is in Christchurch but he will just outsource an auto electrical job anyway.
intrade, Jul 31, 6:09pm
i removed the alarm immo in my punto in 5 minutes with a side cutter
bigfatmat1, Jul 31, 6:29pm
what a wise man he is.
lythande1, Jul 31, 6:57pm
Why not fix the fobs. I love mine. One of the better things on newer cars.
franc123, Jul 31, 7:38pm
If I owned an older tech 4WD in Chch I would probably be repairing the immobiliser system if economic to do so or else replacing it with a new one. You can probably guess the reason why.
msigg, Aug 1, 12:43am
Just trace the wire with a $300 torch and gl from there.easy if u have time.
sw20, Dec 15, 11:46pm
Wait till you get a car with a push button start and proximity key.
