Corrosion WOF
v8_mopar, Jul 28, 3:51am
09 FG Falcon. Failed on corrosion in the engine bay. This is surface rust only, I could clean it up with a steelo pad or wet and dry. I thought you could fail if it was within 150mm of a structural point. This rust is 310mm from the suspension bolt, the point he failed it on. And its 170mm from above the front wheel.
I just cant see how its a wof problem. am I seeing this wrong?
saxman99, Jul 28, 4:25am
My guess is he's failed it on section f, which essentially says he can fail anything he doesn't like the look of.
1. The structure of the vehicle (shaded areas of Figure 3-1-2) has visible:
a) deformation from the original shape that has affected the vehicle’s structural integrity (Note 1) (Note 3) (Note 9) (Figure 3-1-4), or
b) cracking, or
c) fracture, or
d) corrosion damage (Note 2) that is individually larger than 50mm in diameter (Figure 3-1-1), or
e) corrosion damage within 150mm of the top of an A-pillar (Figure 3-1-2), or
f) any corrosion that the inspector considers has caused weakening of a load-bearing structure (Note 6), or
g) poor repairs that have not returned the structure to within a safe tolerance of when it was manufactured (Note 3) (Note 6), eg:
i. filler has been used in an attempt to conceal corrosion damage or deformation of a component
ii. a high strength steel component has been heated
iii. a component has been strengthened.
franc123, Jul 28, 4:32am
Care to post some photos? Sounds like BS to me if it's just surface scale.
v8_mopar, Jul 28, 4:39am
Its a tough call thats for sure.
I could sand and paint it within 10min but will I need proof its fixed or is that all I need to do. There is no welding or fill need its just surface rust.
How do I post pics?
wind.turbine, Jul 28, 4:40am
do that and go else where for a new wof, simple
peanuts37, Jul 28, 5:05am
Load pics on computer, go to 'my trade me', then' view my trade me' down to 'my photos' 'up load photo' browse, select photo, click on it then open, wait for photo thumbnail to show, double click it to open full size then copy address in address bar and paste here. Think I ive got that right from memory.
intrade, Jul 28, 5:07am
kazbanz, Jul 28, 6:51am
Personally l would sand it smooth and just spray Brunox on the rusty bit let them recheck seeing it’s nothing . Then with a wolf finish the painting etc
franc123, Jul 28, 7:02am
You know a wolf that is a competent body shop hand?
apollo11, Jul 28, 7:32am
A wolf will always be a wild animal. Too dangerous for anyone if not an experienced handler.
v8_mopar, Jul 28, 4:50pm
There is no rust under the plastic at the top of the pic
https://trademe.tmcdn.co.nz/photoserver/full/1372953746.jpg
mrfxit, Jul 28, 4:59pm
Yep I can see the issue.
Theres clear evidence of water flow from behind the panel in the form of rust staining.
Whats behind that panel, is for the owner/ panelbeater to sort out.
Why is there water behind there?
it's also a sealed joint which will be holding a certain amount of water behind it.
That said, Wof rust always used to be anything within the suspension area & upwards to the body, including at the most forward & rearward points of the suspension.
Bottoms of mudguards/ valances/boot lid lips etc were not included.
They seem to be trying to include ANY rust in ANY spot now
kazbanz, Jul 28, 9:10pm
OK OK smart guys. -I pad miss key.
kazbanz, Jul 28, 9:28pm
White and rust--a not so good combination come WOF time.
My opinion here-get some decent cutting compound and clean that area up with the cutters. See what it looks like cleaned up. Don't in any way try to repair the area.
v8_mopar, Jul 29, 5:23am
Good starting point. Ill do that this weekend.
Thanks for all the input.
h.e, Jul 29, 5:33am
Drivers side directly under the wiper plastic aye, Just fixed the same thing last weekend. Might pay to take the plastic off as mine was starting to bubble just beyond where I could see. Easy as fix
v8_mopar, Jul 29, 5:46am
yep thats the spot
h.e, Jul 29, 5:57am
Directly under that the body work curves outwards and there is a hole that a wiring loom goes through. Have a look just above the hole there is another seam that may be bleeding as well
larryandfred, Jul 29, 7:00am
Even if your got dodgy looking surface rust, go over the entire car & scrape it off & disguise it before WOF time, saves hassles of none structural rust not passing, if you can be bothered.
lythande1, Jul 31, 2:47am
Go on then. Then take it for its recheck.
kazbanz, Jul 31, 3:30am
My suggestion --grab an old toothbrush and some jif if you don't have cutting compound that will be small enough to scrub the surface rust off -Im betting that's all it will take
headcat, Aug 1, 2:54am
A wash with diluted phosphoric acid would remove the staining.
v8_mopar, Aug 1, 11:32pm
My opinion still stands that it was not a wof issue but in saying that there was a very little bit pitting starting.
https://trademe.tmcdn.co.nz/photoserver/full/1375393897.jpg Plastic off, a quick sand and it looks all good. https://trademe.tmcdn.co.nz/photoserver/full/1375394096.jpg
A paint under a tarp cos it started raining and should get its wof. A couple more coats once it stops raining tho.
https://trademe.tmcdn.co.nz/photoserver/full/1375394211.jpg Shes still a great work horse so patch-o patch-o. Sad days I cant get a newer one. The 4x4's are to high off the ground to work out of. https://trademe.tmcdn.co.nz/photoserver/full/1375398836.jpg
h.e, Aug 2, 6:18am
That looks worse than mine was but was it worth a fail? At least you got an early warning for an easy fix.
Check out my earlier post and have a look directly under this spot
