Carby?
falcon74, May 28, 4:02am
Can a worn carburetor spindle cause flooding?
strobo, May 28, 4:18am
In a way yes , assuming you mean the butterfly spindle? worn shaft or bushes causing air induction and reducing max vacuum pressure in the venturi chamber altering fuel/air ratios ,The fuel will more likely leak out the sides of the carb and flood inside the carb to that eefect!
falcon74, May 28, 4:32am
that is what is happening. thank you quite a lot of play
strobo, May 28, 4:40am
It can be fixed if the shaft is ok and the rest of the carb is ok.Not many carb shops around these days ,unless you give it a go yourself fitting new bronze bushes. Otherwise time for another carb.
sr2, May 28, 4:48am
What type of carb?
falcon74, May 28, 4:59am
AISAN
gph1961, May 28, 5:04am
whats for dinner?
tripe
strobo, May 28, 5:10am
shut up you and your 4 words worth! Can you not read "it has quite a lot of play" ! And what's with answering your own question lol
gph1961, May 28, 5:54am
settle
strobo, May 28, 6:02am
Aisan carb . OP The bushes are still in stock and available, like around $ 9 each , or more$ for a shaft rebuild kit including new shaft, butterflys etc.via post ,so no biggy cost ,Just do your own keyword search and go from there >I'd hate to pay for a new carb ! also try local for a good second hand carb and use the other for spares if the vehicle is a keeper. ie and at other places like https://www.ricambicarburatori.com/contents/en-us/d824_Aisan_Carburetor_Parts.html
falcon74, May 28, 6:14am
Thank you strobo
sr2, May 29, 3:27am
Although not overly familiar with Aisan carbs with some decades of tuning carbureted engines under my belt my answer would be no, in most cases worn throttle spindles will not cause a carb to flood.
First port of call would be float valve, float level adjustment and float integrity (i.e. does it still float). A small note here that over vigorously pumping the pedal on startup can also cause an engine to flood.
Worn throttle spindles will however make an engine a nightmare to tune at lower rpms and partial throttle openings; with variable venturi style carbs this nightmare has the potential to rapidly become a horror movie! (Thankfully to the best of my knowledge Asan carbs are fixed venturi).
gph1961, May 29, 3:41am
good on you for doing more than 4 words
I couldnt be bothered
no tripe for you
redhead18, May 29, 4:13am
mmkkaayyyyy
done many AISANS. LOL
moot point what part of ASIAN?
Is this one from?
I.E. DCG306?
Tip what is the engine?
And NOPE worn throttle spindle bushes do NOT cause flooding but well as per Post#12
redhead18, May 29, 4:15am
4 words.
[Flooding Asian Rice Paddies]
sr2, May 29, 4:21am
LOL; it appears that some of our posters may have started their drinking early?
strobo, May 29, 5:18am
Good points ,many reasons for flooding ,stuck on auto choke is another common one also more apparent with changing seasons.Every worn out spindle bush ive ever come across had leaking flooding and running problems .I accept that Op has checked those other things and the reason for his post because the flooding issue is still there.Friday night drinking ha lol.
strobo, May 29, 5:26am
Datsun 1200 prior to 1982 or Nissan 1200 onwards , aisan made in Japan which is part of east asia.I Worked for a Nissan franchise at GT Gillies in Oamaru from 79 to83 and we did the badge change over in 82.
gph1961, May 29, 5:33am
DCG 306 is Hitachi B110/ B210/B310 etc
leave the pub
go home
strobo, May 29, 5:40am
#16 Some later aisans had 2 throats ,the other suited for 3/4 throttle opening > onwards ,more fuel delivery and max power.
redhead18, May 29, 5:41am
Nah THIRSTY=LOL
Keerist is this where we roll to missypussy and WHAT?
vacuum advance tubes feeding secondary actuation?
vacuum diodes fitted backwards causing overchoking?
Sheesh
[Probably done more throttle bushes than you have had Hot Women?
sr2, May 29, 5:43am
Always fancied redheads.
strobo, May 29, 5:44am
holy shockers , finally you utter a few more words must be a first for you ,keep it up grandad ;-) nope staying at pub for now thanks .
redhead18, May 29, 5:51am
L M F A O=As Ya Juss do.
Meh zee old float moving over minimal range and well.
ya ball has worn a hole mine friend.
and ya ball=caught on zee worn dag on zee edge of yon same hole
Like zee 28 pond snapper. or?
Does dis P. ng contest go to catching fish?
redhead18, May 29, 5:52am
sshhhhhhhhhhhhhhhhhh
LOL
