Tow bar fitting
211061ml, Jan 7, 1:17am
I have a 2013 Mazda CX5 and I need to have a tow bar fitted. Any recommendations?. Thanks.
kazbanz, Jan 7, 1:18am
Mazda themselves.
Otherwise I suggest Auckland Towbars.
tamarillo, Jan 7, 1:47am
ET engineering
intrade, Jan 7, 2:14am
i hope you know that it wont be cheap and i also hope you dont have a cvt transmission because they are not made to tow nothing. plus you need a computer with the towbar programmed in to the system so the stability control knows when you have a trailer hooked on or not 1200$ to 2500$ for a towbar is what you can expect to pay if its done right.
franc123, Jan 7, 4:01am
I would try and find a good used approved Mazda one and whatever wiring components you need to accompany it.
alowishes, Jan 7, 6:25am
Go the wrecking yard route, it’ll save a lot compared to a brand new one.
spead, Jan 7, 7:51am
any mazda dealer
martin11, Jan 7, 7:01pm
Well over the price for a Tow Bar . You do not have a clue .
Second hand
https://www.maztech.co.nz/?s=tow+bar&post_type=product&taxonomy=product_cat&product_cat=0
Plus interface
211061ml, Jan 7, 11:58pm
Thanks for your recommendations. I will check them out.
jmma, Jan 8, 12:24am
Just scroll on by then, easy. Or maybe you have something to add about the subject and before you say it, No I haven't :oP
jmma, Jan 8, 12:26am
OK $454 for towbar. How much for interface and fitting?
sanders4, Jan 9, 8:39am
Towbars are dangerous it seems - so many deleted posts
rkauto, Jan 16, 9:11pm
Lockon ,
2000kg braked
750kg unbraked
88kg tonque load.
Also come with wiring interface .
We do plenty of these for car dealers in our area,around $800 fitted and wired but depends on lockon dealer .
intrade, Jan 16, 9:21pm
1200$ upwards if manufacturer dont have a towbar then dont fit one if its a cvt. you dont want the push-belt fall apart when its not made to tow stuff.
martin11, Jan 16, 10:12pm
Absolute rubbish your price :
https://www.towright.co.nz/product/mazda-cx5-2012-on-class-3-1501-to-2000kg/ Plus about $100 for module and wiring kit . Plus fitting .
intrade, Jan 17, 1:19am
https://www.ebay.com/itm/Skoda-Octavia-III-Tow-Bar-13-Pin-Wiring-Kit-LED-305406300113-Westfalia-OEM-/274333750492
thats just the wiring kit and no one is going to sell it to you in new zealand at that price you also have to pay shipping on top.
not to mention the cost to dismental a car to fit a wiring loom and then programm it to the stability control system
and the cost of the tow hitch. Good luck finding a professional who does all that for free.
intrade, Jan 17, 1:27am
460 au is 600 nz plus 450 for secoundhand towbar usually also 700 + for a factory kit 600 and 700 is 1300$ without labour 4,5 at 120$ to insltall 540$ and 150$ programming . is what the true cost is. + 15% gst. my figures are sound. and on lower mid limmit price
100$ is a canbus shorting out kit morons fitted to that mercedes 2003 model C class. instructions clearly said not to be used with vehicles on canbus. they used the bus as a ground . Limp mode each time a trailer was hooked up.
martin11, Jan 17, 3:33am
So a 2013 Mazda CX5 has now turned into a Skoda Octavia III according to intrade !
rkauto, Jan 21, 3:15am
Intrade read what I said ,we supply and fit them for $800
No programming required ,just fit electrical interface .2.5 hours total.
Have done dozens of them.
martin11, Jan 21, 8:05pm
Do not worry Intrade cannot read o/p's quotes .
intrade, Jan 21, 9:15pm
The towbar team also fitted a electrical interface to the mercedes . and the thing was in limp mode after .
i am not claiming you do anything wrong . but if the vehicle has stability control it must be fitted with the computer module who talks to the cars stability control system and let it know if a trailer is attached .
if you just go install nilly willy some sort of modules that do not talk to stability control then you are liable for manslaughter if the owner crashes because the stability control put the car with trailer in to a ditch as worst case. If it has no stability control cheaper methods are available
Westfalia jaeger and then other ones Like the australian one who said not for canbus in clear english instructions. This tow team fitted to the merc with canbus and stability control.
intrade, Sep 25, 1:46pm
here you go same module for a mazda
i am not a fan of others as they do require wire splice westfalia is plug and play for some makes for some it needs coding like VAG groupe cars.
https://www.ebay.com/itm/Mazda-CX5-Tow-Bar-Wiring-Kit-OEM-343056300113-Westfalia-Genuine/274333749958?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20160323102634%26meid%3Dbd9eaf8720ed476599e8bd19a5a2bdab%26pid%3D100623%26rk%3D2%26rkt%3D5%26sd%3D293110160452%26itm%3D274333749958%2
6pmt%3D0%26noa%3D1%26pg%3D2047675%26algv%3DDefaultOrganic&am
p;_trksid=p2047675.c100623.m-1
This is whats required if it has "stability control" there is no other way other then obviously the wrong way that i pointed out can lead to manslaughter charges.
