Key Fob Programming 2008 Fuga 450GT
testbot_420, May 27, 4:07pm
Having just paid for a replacement key fob I now must wait until mid June for a Nissan Tech to become available to program it costing $250 labour to do, which I'm sure is a 2minute job.
Anyone had any luck doing this themselves? Before I try disconnect/reconnect ECU, Battery, ignition etc?
TIA
gph1961, May 27, 4:10pm
they say its 4 minutes
franc123, May 27, 5:41pm
Actually its not. You've been quoted that because some of those Nissan imports are pigs to program up, it can (but not always) be time consuming. Blame Nissan Japan and some of the complicated ways they go about simple things, not the agency
bigfatmat1, May 27, 6:22pm
alot of cars can be a pain in the ass to programe keys and remotes. Also very time consuming. Also there's the scan tool charge in there.
saxman99, May 27, 6:43pm
Ask your local locksmith if they can do it.
tamarillo, May 27, 7:31pm
oh the irony.
franc123, May 27, 7:45pm
Poor Euro technology has been the cause of much of Nissans problems in the last 20 years. Things would be very different without Renaults interference.
kazbanz, May 27, 7:53pm
Its only $250 all up to have someone like Phoenix smart key services come .supply and cut/program a key/fob for you
intrade, May 27, 8:10pm
Make sure you have all key present , as in most case you erase all keys and load all present ones in on a Nissan. Also ask for the pincode As owner they should give it to you
testbot_420, May 27, 10:23pm
It's a push to start proximity sensor. thanks though
tamarillo, May 27, 11:20pm
wow.
bigfatmat1, Aug 3, 2:05pm
Shouldn't make any difference.
