When I was building trailers I would cut the stubs and disk brake flange off a McPherson strut with a gas axe, pop the stub in the lathe and clean up a flat surface and weld it to my axle. Bolt on stubs on cars are few and far between. Muzz67 has shown you an easy option.
martin11,
May 6, 5:58pm
Think the mid 50's Austin had them and also something else around that area .they were not very strong . and would be hard to get now .
gettinggrey,
May 6, 6:36pm
The old Zephyrs had that bolt on front stub didn't they?
toyboy3,
May 6, 6:41pm
Humber 80 after using the angle grinder , used the brake backing plate threaded holes to mount the stub
saki,
May 6, 9:38pm
I had a honda bolt on stub with hub I was going to use on a trailer.
alowishes,
May 6, 10:45pm
Yep. Mk1 Zed cars.
kingfisher21,
May 6, 11:00pm
Suzuki Swift rears
saki,
May 7, 1:55am
yes lets get away from zephyrs quite a few front drives have bolt on rear hubs.
differentthings,
May 7, 1:58am
ST190 Corona have bolt on stub axles on the rear (mine had disc brakes)
absolute_detail,
May 9, 4:19am
Land rovers have bolt on stub axles
magoo2,
May 9, 8:36pm
mk1 zephyrs had bolt on stubs and the hubs have 5 studs. the killer with these is that inner and outer wheel bearings are about $100 EACH
tegretol,
Aug 10, 9:44pm
So the stub was drop forged/high carbon and the axle would have only been mild steel. What welding rods did you use and did you preheat either part?
