Thinking of buying a Rover 97
snapperitup, Sep 14, 4:48pm
Anyone have an opinion on this or what to look for !
xraps, Sep 14, 4:52pm
Which one !
mugenb20b, Sep 14, 4:56pm
Rover 97 doesn't exist.
richard198, Sep 14, 5:08pm
Rover P7 (V8) perhaps!
pollymay, Sep 14, 5:08pm
Something that isn't a rover.
richardmayes, Sep 14, 5:14pm
A Rover 95 is a car.
A Rover 75 is a car.
There's no such thing as a Rover 97.
A 1997 Rover is probably not too bad if it is cheap, AND it has a new WoF & Rego on it, AND you can convince yourself it's one of the ones with a Honda engine not one of the ones with an Austin-Rover engine.
snapperitup, Sep 15, 5:54am
Hi guys what i meant to put that it is a 1997 rover 216 sli for 1400 dollars, it is in good condition got a wof and redgo any suggestions on what i need to check or opinions !thanks.Is it a good price !
mgmad, Sep 15, 6:12am
That's a very good price. Check the condition of the oil and water, any signs of mixing generally means it's overheated. However, if it hasn't been used for long trips, it can just be condensation in the oil as the car hasn't been allowed to get up to temperature. Often a good run will cure this. If it has overheated at all, it's important to work out why and make sure the problem was fixed. Often it's a problem with bleeding the coolant system leading to air locks, or a problem with the thermostat. Neither are major issues in themselves but like any alloy engine if left and it leads to overheating, can cause more major issues.
Other things to look at: at their current age, some cars are having issues with headlinings dropping, but certainly not all. The cloth trim on the door cards is also at the age where the glue can be giving way, but both of these are very easy to spot issues. The CVT automatic is OK, but not the strongest box in the world. The manual gearbox isn't too bad, and will certainly cope with the stress from the 1600. They don't tend to rust, and no real problems with the suspension and brakes, but always check for condition.
Very competent, comfortable car that handles well, if not overly sporty (the vi version solves that problem though). Mum's 97 216 has nearly 300,000 km on it and still going strong.
lovemore_mbigi, Sep 15, 6:33am
Useful, chuck away runabout for that price.
Be a bit wary if the plan is to travel long distance out of town on a regular basis.
snapperitup, Sep 15, 6:34am
Excellent reading mate thank you, and the roof lining is all good Yeah i thought it was a good price, considering pre 90s cars are selling for 1000-1600 approx.Thanks for your input.
snapperitup, Sep 15, 6:39am
No mainly local but will be planning to drive outta town over the xmas holidays
mgmad, Sep 15, 7:42am
There really is nothing to be scared about, particularly if you check the oil and coolant once in a while.
richard198, Sep 15, 7:55am
My old man had a 216 & it was heap of shit (Honda) Spent more time in the workshop than driving.
doug207, Sep 15, 9:18am
That doesn't exist.
owene, Sep 15, 9:53am
I'd check my bank managers views first. Have you the vaguest idea what spares for those things cost! And remember that they are notorious for special parts. I ran one in UK for a few years and it nearly broke me. If you really want a european, stick with Volva coz they are built like brick sh*houses and do last.
tgray, Sep 15, 10:45am
Rover, rover, won't turn over.
Some cars are not good at any price. I wouldn't.seriously.
mgmad, Sep 15, 11:01am
Expensive and specialist parts! really! Not at all, most service parts, and a lot of general parts, are kept in stock in NZ. Parts supply is pretty good for them, still an official agent here for X-Part (the parts suppliers) and a number of specialist garages around the place. Parts are more expensive than for an MGB or Mini, but no more expensive than other comparable cars.
rover79, Sep 15, 11:59am
Bloody great little pocket rocket they are.
Had one for 2 years and learnt that they had an over heating problem, had been told if it hadn't happened already, then it will happen, but once fixed should be all good, think it was to do with the type of head gasket.
On keeping an eye on them on here for awhile and seeing some advertised as parts as had overheated it proved right.
richard198, Sep 15, 12:05pm
Was thinking of Leyland P76.
rover79, Sep 15, 12:30pm
speak of the devil.
Just searched,rover 216 slion here and there are 3 cheap ones out of 11 that mention headgasket problems and they are around the 100k mark, I was told when owning mine the overheating problem will likely occure around the 100 thousand km mark.
richard198, Sep 15, 12:37pm
Head gasket problems were ongoing with my dad's Honda (216)! And they started well before 100 thou. K.
He traded it on an Ocatavia. The best VW Golf that VW never built!
mgmad, Sep 15, 1:00pm
It's not really the headgasket that gives the problems, they will go if the car overheats, but seldom cause the car to overheat. Generally a much simpler problem, such as thermostat or airlock.
snapperitup, Sep 15, 1:40pm
I just figured out that my transmission is sweet took it to an transmission place thinking the trans was stuffed because it wasnt changing gears but he said they dont have gears thank god for that i thought i bought a dud lol .
richard198, Sep 15, 2:08pm
Yeah, it's a variomatic from a Daf. Belts between two cones.
johnnyrotten3, Sep 15, 2:46pm
if its a P7 its like rocking horse poo.
