Chopper crash at Viaduct Basin.
Page 1 / 3
rob_man, Nov 23, 10:36am
Looks like a mechanical failure.
http://www.youtube.com/watch!v=3bOOyhUnOZA
a.woodrow, Nov 23, 10:45am
Hell I hope he was ok! hear the bang as something fails
rotormotor7, Nov 23, 10:46am
all sweet.avoiding the poles.NEK MINNIT
a.woodrow, Nov 23, 10:50am
They are saying on news that he hit a cable
Do you hear the moron on the clip, don't worry about that - call the news room. yeah don't call 111 for the pilot we can sell this tape for money
rob_man, Nov 23, 11:00am
I was wondering, a cable around the tail rotor might cause the tail section to snap off like that if the rotor was stopped suddenly and all that torque was loaded into the frame.
ontwowheels, Nov 23, 11:10am
more likely thatone of the main rotors hit the cable and broke, the resulting vibrations (as seen in the video) would be more than sufficient to cause the structural failure which has resulted in the tail section seperating from the fuselage
a.woodrow, Nov 23, 11:12am
I don't think it was his tailrotor. If you watch the footage you can see his towline underneath break and flick up - watch the mounting between the skids bounce up and down. I wonder if the cable flicked up into the main rotor around the helicopter body
ontwowheels, Nov 23, 11:14am
snapped winch cables are a cause of a lot of accidents involving lifting choppers. highly possible, and a lot more likely than the tail rotor
a.woodrow, Nov 23, 11:17am
I would even hazard a guess and say that the gunshot sound you hear at 25sec is the sound of the snapped cable reaching the camera
richardmayes, Nov 23, 11:30am
It looks like the engine and main rotor driveshaft starts to thrash side-to-side on its mountings, (like something rotating has become seriously unbalanced) and that shaking pretty quickly breaks up the cockpit body of the helicopter.
Every film I've seen of helicopters losing their tail rotors, the fuselage starts to rotate in the opposite direction to the way the main rotor is going. But it's completely smooth when this happens, no thrashing around like what this helicopter did.
big.b-lil.c, Nov 23, 11:44am
i think i have flown in that machine when it was first imported and painted yellow.
a.woodrow, Nov 23, 11:46am
You won't be flying in it again!
richard198, Nov 23, 11:53am
I think it's more likely that the man on the ground pulled on the tether attached to the chopper and caused the crash!
a.woodrow, Nov 23, 11:54am
lol maybe if he was superman.or chuck norris
lookoutas, Nov 23, 3:41pm
Makes ya feel lucky doesn't it!
I've flown in 6 helicopters that are now wrecks! One was about an hour after I got out.
Add to that, about 5 Fletcher's.
Looks like the driveshaft shat itself.
gunhand, Nov 23, 3:46pm
It was John Key And the governments fault, "AGAIN"
trogedon, Nov 23, 4:08pm
With your record.give up flying.
a.woodrow, Nov 23, 4:10pm
I've watched the footage over and over and I cant see the rotor strike they speak of. Will watch with interest for the CAA finding on this
rob_man, Nov 23, 4:14pm
You can see it on the big screen if it's slowed down a bit, there's a blue cable hanging parallel to the black pylon in the foreground and it gets drawn into the rotor.
One News just showed it.
74nova, Nov 23, 4:19pm
It was the idiot holding the cable, he pulled on it. I'd hate to be in his shoes.
bitsy_boffin, Nov 23, 4:19pm
The newer footage that 3 (and 1!) showed clearly shows that the main rotor snagged a cable, I wouldn't be surprised if said cable actually wrapped around and guillotined the tail.
electro2000, Nov 23, 4:50pm
You might laugh but choppers are finely balanced we do a lot of work with
them lifting and transport on and off hill tops. At the hover or comming in to land they can be pulled off balance very easerly if the pilot doesnt react quick enough ie you never try hop in or load while on the hover unless pilot is aware or you will pull it over.
However in this instance it looks like the crew on the ground flicked that
cable in to main rota
rsr72, Nov 23, 5:08pm
Thank God it didn't land on a nearby Superyacht.
That would've created a real fuss.
richard198, Nov 23, 5:21pm
I rest my case!
(Not superman or Chuck Norris)
(The ground crew are lucky their hand wasn't ripped off!)
electro2000, Nov 23, 5:29pm
Should add its thepilot that keeps it balaced with his counter actions ,plenty of hand / feet coordination required to keep it in the sky
