Whats the gos on these new 'multi' tools
skin1235, Dec 19, 7:40pm
the ones that can cut chunks, pipes, nails, etc, uses a vibrating head or something, the ads make it look so simple and fast but has anyone here actually got one yet and if so just how good are they, some outfit is advertising them at 118, gotta be worth a crack! no!
morrisman1, Dec 19, 7:41pm
Yes they are great but make sure you dont get a cheap crap as-seen-on-tv. Get a Fien, or for a more reasonably priced option Bosch have them in their DIY and Professional ranges.
mugenb20b, Dec 19, 7:45pm
I've got a Bosch one, comes with 3 different fittings (all you need). Bloody good machine, but makes a lot of noise. I use mine to cut skirting boards and holes in the gib for power points.
mugenb20b, Dec 19, 7:46pm
Oh, and the only thing you can't cut is steel, iron etc. But will go through copper and aluminium.
stevo2, Dec 19, 7:49pm
I have one as well. I thought it might be 3 or 4 times a year sort of tool but I have used it at least once a fortnight since buying it 12 months ago.
Blades are bloody expensive though.
If you get the Bosch, get the one that comes in a kit box and has a few blades and sander pads. About $160
Cheers Stevo
skin1235, Dec 19, 7:49pm
Nails!
skin1235, Dec 19, 7:50pm
have a renovation job in the late planning - gotta get started soon stage that could definitely use a good nail chopper
skin1235, Dec 19, 7:51pm
whats the issue with the blades stevo, do they break , wear out, lose their edge type thing!
mugenb20b, Dec 19, 8:13pm
Not recommended for nails. I use a Makita sabre saw for that, not sure if that's their correct name.
skin1235, Dec 19, 8:15pm
if it's not the right name it will suffice, I know the tool you mean mugenb
skin1235, Dec 19, 8:16pm
and I loaned mine to a brother a few years back, never seen it since
easygoer, Dec 19, 8:28pm
I bought the Blue Bosch, I had a look at the parts drawings for the Green Bosch and felt the gearbox could be a bit on the light side, I have been cutting through stainless staples and brass screws with no major problems, the blade I was using is now blunt but new blades on TM are cheap enough
thejazzpianoma, Dec 19, 9:01pm
Me too, I have the bosch one, nails are supposed to be O.K so long as you use a good bi-metalic blade.
I can tell you in a few days as I have blades on order, someone else is bound to have tried the bi-metalics already though.
stevo2, Dec 20, 4:08am
The blades just blunten. There are blades available for cutting everything from nails and light metal to softwood and hardwood. I might try the Blue Bosch next time round as its the tradies version
skin1235, Dec 20, 4:21am
ta mate, think I may have to go sit on santas knee for a wee while
the-lada-dude, Dec 20, 5:45am
i thought you were a vehicle mechanic, and it turns out your really a builder in disguise !mugenb 20blol
the_don_61, Dec 20, 6:49am
The add on TV shows all the tools you dont need any more.
1 is a drill.how do you drill a hole with a moving blade!.
1/8 hole please .I think that tool is a joke.
intrade, Dec 20, 6:57am
they where originally for panel beaters cuttimg holes in cars, guess they made cheaper diy versions if they dont cut steel now .
fryan1962, Dec 20, 7:14am
I have a blade for cutting steel in mine, my sparky saw mine when he was here and next visit he had bought one and loves it
I bought blade from the us they are made in japan better quality
budgel, Dec 20, 10:21am
Blades are cheap on ebay.
mugenb20b, Dec 20, 10:27am
Nope, not a builder, but I do do my own building. Currently adding internal walls in our 120 square metre master bedroom. It's too big, so I'm making 4 rooms out of 1. I also have a rental property in Upper Hutt, did lots of renovations before I let it out. And, I used to have my own heat pump business, so yeah, the Bosch multi tool was very handy indeed.
the-lada-dude, Dec 20, 11:42am
yeah and i just love wood and hammers, i buy the nails that are pre bent !
tmenz, Dec 20, 1:12pm
I've got some joinery to do in the near future which involves cutting out sections of skirting and ceiling moulding - I've been puzzling over how to do this neatly and effectively - will one of these tools do the job without too much collateral damage!
thejazzpianoma, Dec 20, 2:45pm
They are perfect for that. That's what the clip together laminate floor guys use. Instead of removing the skirting they just cut right around it at the height of the floor.
tmenz, Dec 20, 4:21pm
Great - off to Mitre10Mega/Bunnings tomorrow to have a look!
