Ive just lost reverse, help please
bambi1985, Feb 16, 12:27pm
car was fine, all gears working just used reverse 5 mins earlier andnow it wont go into reverse, no crunching from any gears b4 or after this, help please
intrade, Feb 16, 12:29pm
what car make model automatic or manual !
bambi1985, Feb 16, 12:30pm
1990 300zx, na manual, had a new clutch pt in 2 months ago
intrade, Feb 16, 12:33pm
ok its hopfully just the selector that has poped off you want to check the linkage from leaver to box .
bambi1985, Feb 16, 1:53pm
it is not cable it is hydrolic selector is fine still very lost, any more ideas! it wont go in at all! no crunching just wont go into reverse, all other gears are fine
mechnificent, Feb 16, 2:22pm
Does the lever move the full travel!
Does it stop short, or, feel loose when you try to move into reverse!
bambi1985, Feb 16, 2:29pm
stops short, no loosness or crunch
bambi1985, Feb 16, 2:34pm
help please!!
mechnificent, Feb 16, 2:47pm
Ok, if the lever doesn't move the full travel, and given that the box was out a while ago, then it's probably something in the lever or linkages.
If you are able to pull the centre consul out and the rubber boot off I think you will be able to see the most likely trouble spot just right there at the bottom of the lever.
It could be that there is a plate that holds the lever, probably got three or four bolts holding it. the bolts may be loose. .
Is that right guys! This lever would go straight into the box wouldn't it!
I'm assuming that it is a rear wheel drive.
If it'sa front wheel drive then you might have to get underneath and have a look at cables or linkages.
Either way, I doubt it's anything that would need the box taking out. It should be fairly simple to fix.
mechnificent, Feb 16, 2:51pm
if the box didn't make any big bangs or graunching noises then I doubt it is anything inside the box.
bambi1985, Feb 16, 2:54pm
gear shifter will move over to reverse but will not pull back in2 gear, is it possible that i have lost reverse gear and have to get a new gearbox!
i have pulled the hole gear shift assembly apart, is slightly worn and sloppy, but there is no restrictions that i can c that could stop me getting in2 reverse, gear shifter moves freely to the reverse positionbut does not pull back from neautral
bambi1985, Feb 16, 2:55pm
it the missus hes in the car, trying thro the top, any other ideas!
bambi1985, Feb 16, 2:56pm
luckythirteen wrote:
I just thought of the reversing switch which is pressed at the same time reverse is selected. If the switch has seized for some reason then I don't think reverse can be hooked. Also when the switch falls apart the pieces usually end up in by the selectors.[/quote
where would this switch be! bf hasnt seen it!
bambi1985, Feb 16, 2:58pm
i was driving did a 3 point turn, then drove off, went to paralell park had no reverse, car was not turned off between this time
bambi1985, Feb 16, 2:59pm
so frustrated, just spent a heap on new alternator, battery, clutch, bonnet, locks, panels, broke now, hope this is a cheap fix.getting very frustrated, poor bf, any more help guys, could it b sumthing stupid simple, i hope so
mechnificent, Feb 16, 3:01pm
Well. I'm out of guesses.
I suppose you have checked there is oil in it!
Tried using a screwdriver to select the gear without the lever in there!
mechnificent, Feb 16, 3:02pm
I'll see if I can find an online manual and have a look at what sort of box it is. then get back to you.
bambi1985, Feb 16, 3:07pm
vg30de manual gearbox from a nissan 300zx 1990
bambi1985, Feb 16, 3:09pm
where is switch located!
mechnificent, Feb 16, 3:09pm
http://www.300zx-twinturbo.com/cgi-bin/manual.cgi!list=mt&dir=&config=&refresh=&cycle=off&scale=0&design=default&total=37
Exploded view of the box here/there.
If it was low on oil it is possible the reverse selsctor might baulk at going in to gear.
Check the oil.
Apart from that, if it's not in the top by the lever then it does sound like an internal gearbox problem. and those are tricky boxes to do.
skin1235, Feb 16, 3:09pm
so the gate selector is working, and the gear selector works on all other gears but won't work on reverse!, can you still get 5th gear ( same gate)
bambi1985, Feb 16, 3:14pm
all gears inc 5 all work, except reverse
bambi1985, Feb 16, 3:16pm
sitting by car hoping for sumthing to work :( bf looking very frustrated,
skin1235, Feb 16, 3:23pm
can you get a photo of how the bits appear under the plate! or does it have to be removed from the car before the rear cover can be taken off
I see that the o/d and reverse do use the same shifter shaft as all the others but do have separate selector forks, maybe as simple as a roll pin broken on the reverse fork
bambi1985, Feb 16, 3:32pm
hes trying to take pics for ya, wont be too long
