Hi Guys, Did mums thermostat today, (nissan sunny, 1.5, 97) It was reading high on the gauge(sp!). Any how it was a 78 that I replace with a 74. Fluid levels perfect, but temp still reads just under the 3/4 mark. Anyone know where these should sit as a genral rule!
dent,
May 27, 6:03pm
no more than half way I would of thort
jsbike,
May 27, 6:08pm
factory gauges dont show you what temp the engine is,all they do is show you temp difference, ie 2 cars of the same make and model may have completly different readings on the gauges but will both be operating at the same temp. Bad idea changing the thermostat for a different one when you have no idea of the actual temp its operating at.
May 27, 6:11pm
Are the fans working!
ginga4lyfe,
May 27, 6:13pm
have you had a look under the oil cap! any white sludge under it!
bigracket,
May 27, 6:15pm
Fans workin
bigracket,
May 27, 6:19pm
Very slight it just looks like condensation though cos its so slight and just around the filler cap, the car barely gets used from one month to the next. I would be very surprised of it was head gasket, def not other signs of head issues. and def has not been overheated (like boiled or anything)
bigracket,
May 27, 6:20pm
Thats a point.
foebangn,
May 27, 6:26pm
you chek 2 see if there z ne air traps in radiatr or hoses!
jsbike,
May 27, 6:26pm
I only know as I has a similar experience. my ex's rav4 ran like dogs balls and the although the temp gauge did go up to halfway, it would move between 1/4 and a 1/2 when driving. I checked it out and found the motor had the thermostat removed.so I replaced it. whenI did this the gauge went to FULL hot but it was a stuffed gauge, the temp was actually fine. the previous owner must have removed the thermo when the gauge started reading hot, as a result it ran like balls as it was cold, even though the gauge said 1/4 to 1/2
foebangn,
May 27, 6:26pm
air locks
bigracket,
May 27, 6:36pm
Cheers, airlock is not impossible, So are we all in agreementthat just under 3/4 seems a little high though in average terms!
johnf_456,
May 27, 6:37pm
Check the fan operation.
May 27, 6:39pm
Read posts 4 and 6.
jsbike,
May 27, 6:40pm
if the gauge is reading correctly
johnf_456,
May 27, 6:40pm
Nothing wrong with mentioning it again, to backup whats been said above.
bigracket,
May 27, 6:41pm
Oh John you peni, please dont comment on my threads thanks
May 27, 6:42pm
Hmmm.read post 6.
johnf_456,
May 27, 6:43pm
Sorry but you do not tell me what to do, I was trying to helpful. Give me credit I just skipped most of the reading and posted something helpful. Also how have you tested the fan!
Also check the flow!
bigracket,
May 27, 6:44pm
DONT COMMENT IN MY THREADS !
johnf_456,
May 27, 6:45pm
I am entitled post where I like, freedom of speech
ginga4lyfe,
May 27, 6:45pm
and you wander why people dont like you, if you want to be respected why not respect others, he said not to post in his thread, now wouldnt it be fair to say that he doesnt want you to post in the thread and that if you did it would only lead to more tention! Why not stop stirring !
bigracket,
May 27, 6:45pm
Leave my threads alone ! I am sick of your shat !, just do me a favour please Johnf_456 Done post in my threads please ok
johnf_456,
May 27, 6:46pm
I will not be told where I can and cannot post by anyone. It is also disrespectful to say who can and cannot post. Anyway lets get this back on topic.
ginga4lyfe,
May 27, 6:47pm
Then you cannot bitch when someone takes the mickey outa you or puts you down, as by your ideals that you dont want to be silenced of freedom of expression of freedom of speech then you are to grant them the same, otherwise you are biased
Now i will agree that it may not be nice the way some people have talked to you, but hey you only lead it on
