NEW LAWN MOWER
flybye_in_a_rx7, Mar 29, 5:27pm
might get a new one. whats the main differences between a $400 one and a $1000 one! any suggestions on what to get. i would prefer a cheaper one rather than expensive though
mr_lovebug, Mar 29, 5:33pm
The more you pay the longer it will last & the less problems you will get,I know person that had wheels falling off,then the motor would play up etc.
In the end you get what you pay for.
I had a $900 push mower & it lasted & ran better than the $600 mowers that my friends got at the same time,half of them came to use my mower cos there ones was back at the shop getting fixed again.
biddy6, Mar 29, 5:44pm
I'm really happy with the $ 326 Cobra from Mega mitre 10. Briggs and stratton motor reasonably lightweight, starts first time . I Hose under the deck every second cut before I put it back in the shed. No problems
mr_lovebug, Mar 29, 6:11pm
Yep,my $900 was/is a massport.
Great mower.
fordcrzy, Mar 29, 6:36pm
i love my lawnmaster 2 in 1 mower.the mulcher is FANTASTIC. it looks like you used a catcher even when youve used the mulcher! great!
ralphdog1, Mar 29, 7:00pm
Go buy a Honda, about $1000, thick alloy deck, bearings in wheels, can be put into mulch mode and no Briggs and Shitbox engine.
m16d, Mar 29, 7:09pm
Yer. was never a fan for Briggs "n" Stratton. but this one is.its a6.75hp. Made in Merica.Front wheel drive. starts 1st pull.tows you along as fast as ya want.
gunhand, Mar 29, 7:20pm
I got my massport about 10 years or more ago. Cost about $800 from memory.
Never been in the shop, blades changed 3 times, oil 4 times, carb flushed and blown out twice and thats about it. The handle bolt thingy where it folds came off and was lost and the throttle cable broke so I just set it at the motor and go. Still starts and always has started 2nd pull. No smoke no rust. And thats mowing lawns once a week for the season for ten plus years.
fordcrzy, Mar 29, 7:36pm
lawnmaster is nz made too. my first one was stolen! i must say i preferred the tecumseh motor as it revved slightly faster than the B+S(same Hp for both)
dinoz, Mar 31, 10:01am
Go Victa/Masport/Lawnmaster with an alloy deck, bearing wheels and at least a 5hp engine. I prefer the Honda engines over the B&S ones. More fuel efficient and less problems. A cheap mower won't have any of the above (will instead have Steel body (rust here I come), cheap wheels with nylon bushes, less powerful engine).
sifty, Mar 31, 10:09am
Got me a $8000 ride-on. Mulches, catches and has a stubby holder.
Bliss.
xs1100, Mar 31, 7:29pm
brought a masport last time 4 stroke briggs and stratton, alu body only thing i would get next time is the mulch feature save emptying the catcher all the time
angelab, Mar 31, 8:15pm
15 years ago I bought a 5.5 hp B&S powered Rover. cast iron bore jobbie. Mows 1 hr of lawns each time, oil change every couple of years if I remember. Buy alloy chassis and proper bearing wheels then you can ignore it like a camry! The throttle remote fell apart last year & now I kick the throttle up or down but it starts and goes as well as when it was new and that has been a lot of lawns cut. Gets bad economy but, about a doz speights to the tank!
jmma, Mar 31, 8:19pm
I own a lawnmower repair shop and I see enough of this cheap crap daily, they dont wont it repaired when you give them the cost, just say "Ill be better off just buying another one" dah
Buy Masport etc with alloy deck as most are saying on here
Cant wait till warehouse etc start selling cars (o:
pnh4, Mar 31, 8:28pm
UM, 1000 - 400 = 600
sr2, Mar 31, 8:32pm
Speak of the Devil. My trusty old B&S Masport (has to be 20+ years) threw a leg out of bed just this afternoon! I supose I'll have to invest in another one for the next 20.
jmma, Mar 31, 8:40pm
Someone forget to check the oil and mowed on a little slope aye
elect70, Apr 1, 2:05pm
I boughtM10Vinaro5 years ago,cuts kikuiafinestarts first pull every timegood old Briggs & stratton motor I just buy new bladesonce a yearCostwas&299new
plasticboys, Apr 1, 2:19pm
my $1500massport was a load of crap more things on it to go wrong
mingle417, Apr 2, 1:07pm
my nana had a Masport lawn mower with the B&S motor and so far its been through 3 generations of family. my parents got it when my nana had problems pulling the cord to start it, then i claimed it when it got replaced cause it didnt run very well (All it needed was a tune up and a new spark plug). has to be about 15 years old now if not older and the body is still rust free. however the engine gives up working about 30 minutes through the job till its had atleast a day to rest. no matter what you do, it wont start and if it does start, even a little bit of strain on the motor, and it just stalls lol
rsr72, Apr 2, 2:43pm
How does an OHV engine mower compare with a 4Stroke!
Are they worth the extra cost!
paull, Apr 2, 3:18pm
there are mowers and then there are MOWERS ! you wont a good reliable mower that will go for 20 years then go a contractor series, i have gone honda with the self drive and mulch option also comes with a blade break so you can stop the blade while the motor is going and also has a 70ltr bag, yea baby thats the shizzle, i allways check my products via the web site PRODUCT REVIEW, check it out they have reviews on everything and people can put there own opinions up and rate the product out of 5,
if you are gunna go for a cheaper model then i fully suggest that you change the oil every 15 hrs and wash the machine down after every use, every 30 hrs i change the plug and put new blades on this costs all of $30 for the lot ,oil,plugs and blades,check the site" product review"
zetec, Apr 2, 3:57pm
Lawnmaster is the ONLY NZ made mower available new. My Lawnmaster 380 is 23years old, mows a large lawn and still runs strong. I have owned it from new and only replaced a wheel in all that time.
rsr72, Apr 2, 4:23pm
#28 - What do think of the Honda steel bodies, and also their composite (plastic!) bodies!
Do they have alloy bodies as well!
flybye_in_a_rx7, Apr 2, 8:22pm
cool sounds good paull. will check out that site. cheers for the info. and thanks everyone else for your input. think im gonna buy the masport 350AL. $600. alloy body. pretty much the cheapest massport mower
