Wof recheck
cat1340, Mar 23, 9:12pm
if I get a wof done in chch next weekend at vtnz and it fails for some reason can i get it rechecked at another vtnz as i dont live in chch!
jasongroves, Mar 23, 10:39pm
I would assume you could.but a quick call to VTNZ would confirm to save you any hassle:)
Otherwise.you could just get the WOF check done before you go to Chch!
Some tips:
-Do the basics and check your tyres (May as well do pressures at the same time).
-Get a mate to help you check all exterior lights are working.
-Top up your window washer reservoir.
-Check struts for leaks.
-Check CV boots for tears (if FWD/4WD).
-Have a good look over for rust.
-If you have a spare wheel, make sure its secure.
carmedic, Mar 24, 5:54am
Not a reason for WoF rejection.
mugenb20b, Mar 24, 6:39am
Unless the brake components or backing plates are covered in grease.
carmedic, Mar 24, 6:48am
A split CV boot is NEVER a reason for rejection.
Brakes covered in oil or grease is a totally separate matter and does NOT require replacement of said boot to pass.
intrade, Mar 24, 6:53am
if you do go elsewhere you will have to pay again as the money was paid to the first testing station and the other have not gotten any money from you so you have to pay for a newwof if you go elswhere.
mugenb20b, Mar 24, 7:06am
True. A bit of a grey area that one.
OK, scenario for you:
A car fails a WoF inspection due to grease from the split CV boot on the brake components. How would you remedy the problem in order to pass a WoF inspection!
swivel, Mar 24, 7:07am
Think about the obvious answer
mugenb20b, Mar 24, 7:10am
Yes, so obviously, a CV boot is a fail in this case, unless you leave it for another few months until all the grease runs out.
dent, Mar 24, 8:26am
The fail is gresse on braking components. The cause is the c.v boot. But all they have to do is clean the gresse of brakes and its a pass. Not the correct repair but it is acceptable .
mugenb20b, Mar 24, 9:24am
OK, fair comment. Interesting to see how other people go about this problem.
dent, Mar 24, 9:27am
If it was my car or a car that came in to the workshop it would be replace c.v boot and steam clean. But hey we all know what people try and get away with.
bellky, Mar 24, 9:28am
that defies logic.
dent, Mar 24, 9:29am
how!
bellky, Mar 24, 9:32am
seeing it was your quote i'm not surprised at your answer.
sorry if this doesn't help much.
dent, Mar 24, 9:35am
My quote is quite correct according to the wof rule book. If I fail a car for gresse on the brakes due to a split c.v boot, the owner dosnt have to replace the c.v boot just clean off the gresse. Im not saying the repair is the right way to go but it is then a warrantable vehicle.
bellky, Mar 24, 9:43am
whatever mate. grease, doesn't, boot,, i'm. not having much faith mate
dent, Mar 24, 9:45am
Sorry im not quite understanding what your getting at with that coment.
bellky, Mar 24, 9:48am
i'm sorry too mate. please forgive me. it's called ad hominem.
i'm, you're, comment
dent, Mar 24, 10:08am
Yeah im sorry about the spelling not my strong point. And yes you have to explain what the minimum requirements are to get a wof. But also explain the best repair, which isnt always the cheapest.
ryans, Mar 24, 2:36pm
I wouldn't worry about it, the dumb--- doesn't know how to use capitals correctly, so he's probably only using his browser's spell checker to correct you.
bellky, Mar 24, 2:40pm
i don't use capitals because lazy. i'm on internet explorer so no spell check
(presuming you're not talking about carmedic)
carmedic, Mar 24, 4:26pm
Yes he is, he??
jasongroves, Mar 24, 11:44pm
Yes, I know:) But as mentioned above, a split boot is the first step to grease leaking onto components and crap getting into the joint.
If it was me, and the boot was split I would rather pay $15-$20 for a boot now than have to pay for a new CV later.
Its just something that I check on my own vehicles, and pre-WOF time works out well for me for checking stuff like that.
Prevention is the best medicine:)
But otherwise, yes, you are totally right in regards to it actually being a fail.
thewomble1, Mar 25, 1:11am
Surely from the safety point of view it would better to getboot replaced.
