What could be the answer?.
erosmf, Apr 11, 7:07am
My sons Mazda ute is cutting out when it falls below 2000 revs. So when he changes down or when he comes to a stop it cuts out. Hes been using the choke to try and keep it going. It happened quite quickly as he drove it to work fine and then it was rough driving home. Anyone have any ideas! Big thanks :-)
intrade, Apr 11, 7:43am
when was it last serviced! Does it have a cambelt any of the rest of the engine servicedregularly! its usually also good to tell year model and engine it has fitted for somone to guess without using a cristall ball
erosmf, Apr 11, 7:52am
was serviced not long ago.funnily enough it does less ks to the litre now than before the service.not sure on the cambelt.haha, sorry.its a 1989 Mazda B2000 C/Plus.well thats whats on the rego sticker. Maybe not much help!
bellky, Apr 11, 7:52am
Blocked idle circuit or vacuum leak.
erosmf, Apr 11, 7:55am
ok.thanks.bit foreign to me, but I will pass that on to him.
He was hoping it was something he could sort himself, but its just deciding whats causing it.
Sorry, I'm not greatly car minded.as long as they keep going I'm happy :-)
intrade, Apr 11, 7:57am
check carjam.co.nz for engine number.
they could have knoked a vaccume hose it has happened to me once also on them vvti toyota changing the aircleaner pulls off the vaccume hose and then it wont run right after a whle till you plug it back to where it was pulled off. thats just one example.
erosmf, Apr 11, 7:59am
Oh, ok.could that have knocked off by itself, as he drove it to work fine, then the drive home it was crap!
intrade, Apr 11, 8:00am
dont know the cambelt could have jumped 1 tooth to make it run crap also its why we would want to see what engine number it has.
erosmf, Apr 11, 8:01am
ok, sweet, wel he is at work and its here so I will ask him to look, thanks heaps :-)
intrade, Apr 11, 8:02am
if the car is here then tell us the numberplate!
bellky, Apr 11, 8:02am
For it to have a manual choke it's a carbureted engine. Idle circuits work up to around 1800rpm. The reason it's stalling is there's not enough gas to the engine through the carb, or too much air.
First thing check there is no air getting into the engine through the intake - this could be a hose fallen off or a cracked hose etc,
I there's no air leaks then it must be blocked idle jets, although this seems less likely as the application of the choke improves it.
I could be wrong about this. I'm sure others will have other ideas.
erosmf, Apr 11, 8:26am
great, thanks for that, sounds plausable to me haha
erosmf, Apr 11, 8:27am
I wouldnt do that without asking him first, sorry.but I will get him to look it up on the site when he gets home.thanks :-)
thunderbolt, Apr 11, 8:27am
Idle solenoid!
erosmf, Apr 11, 8:33am
being!
needs replacing!
haha
erosmf, Apr 11, 8:36am
Makes me want to go and look under the bonnett now haha.Would be so funny if I could fix it before he could.damn, no keys! haha
bellky, Apr 11, 8:50am
Haha, that would be sweet for sure, but don't be disappointed if you can't fix it lol, as really it could be just about anything lol.
erosmf, Apr 11, 12:47pm
spoke to my son at lunch and he was told the same thing.said a mechanic would have to use process of elimination as well.
My process of elimination was.well, its not the clutch, its not the tyres or the horn.see, I'm pretty good at this stuff :-P
Thanks for everyone shelp, much appreciated :-)
intrade, Apr 11, 12:49pm
good luck and dont forget to post what the problem was.
erosmf, Apr 11, 1:00pm
Thanks and I will, just hope its not too expensive.
He did say he had looked at the hoses and they seemed all ok.so be interesting to find out the cause
roddie1971, Apr 11, 1:02pm
agree here. one or the other
saxman99, Apr 11, 2:02pm
I have a van with the same engine. Recently it started to do a similar thing, although there were other symptoms as well, like the odd backfire and difficultly starting it. It turned out to be a crook distributor condenser, cheap and easy to fix, worth checking I reckon.
beast9, Apr 11, 2:23pm
to check for vacuum leaks get a gas torch dont light it and wave it round the intake manifold while engine is runing if revs pick up then u have a vacuum leak for a block in carby take air cleaner off start engine hold at 2000 rpm and put hand over top of carb dont let motor die repeat 3 timesthats a couple of easy tests
erosmf, Apr 11, 3:56pm
Thanks 'saxman' and 'beast9'
I will definitely pass these suggestions on to my son.
He is stubborn and determined to try and fix it himself.which is cool. Its the only way to learn :-)
Its pouring at the moment so I suspect it may not get fixed.today.haha
erosmf, Apr 11, 4:45pm
Ta.I'm writing all these down to show him, it will keep him busy :-)
