hi there i am broken down 6 hours from homein nelson and needa ignition pack for a 1995 range rover and cannot source one anywhere neither can the garage, if anyone knows of,one been wreaked anywhere please get in touch .
berg,
Jun 10, 6:13am
Newport engineering in Vanguard St. If you can get hold of them they should be able to help. Behind the testing stn
countrykids6,
Jun 10, 6:37am
thanks for that ive tried most of the wreakers but havnt tried them yet,kinda hoping someone sees this who has a range rover in their back yard
berg,
Jun 10, 7:07am
Newport engineering are a bunch of 4x4 drivers and usually have access to plenty of parts within the Nelson area.
countrykids6,
Jun 10, 7:20am
thanks anychance u wouldnt happen to have a after hows number ! thanks so much for ur help
berg,
Jun 10, 7:24am
Will make a few texts and see if I can find where they are. I used to work with one of the guys there
berg,
Jun 10, 7:48am
Seems you have a bit of a problem. Got a reply from my mate and he hasn't got an ignition pack.
bigfatmat1,
Jun 10, 8:02am
independant land rover may be able to help in tahunanui drive. theer is some guy out dovedale with heaps in his paddock as well but would not know how to get hold of them.
rovercitroen,
Jun 10, 8:09am
Try the Nelson Rover Club. Someone there may be able to help you. Sorry, I don't have the contact details.
countrykids6,
Jun 10, 8:32am
thanks guys ur help muchly appreshiated
by_hdt,
Jun 10, 9:01am
Sure its igintion pack!, did my time on these, still see heaps. never replaced an ignition pack.
countrykids6,
Jun 10, 12:51pm
well its burn two ignition coils in the last week, it burnt one out, the garage replaced it and drove about 30km and it burnt the same coil out again , any help is muchly appresheated as there is very little knowledge about the range rovers up here
bigfatmat1,
Jun 10, 1:20pm
main reason for ignition coils crapping out would be worn plugs or faulty leads not a ignition module. the ign module simply holds the coil down to ground for a few ms if it was holding itto ground for to long it wouldnt run I t hink the problem lies elsewher
ozz1,
Jun 10, 2:14pm
hicall mewith in 1/2 hr 03 548 3289.4.13 pmcheers ian
countrykids6,
Jun 10, 5:51pm
thanks for that guys, the leads and plugs were changed after the first coil burnt out
countrykids6,
Jun 10, 5:53pm
hi ian here is my cell number 027357 6363 txt me and ill ring u, other wise i keep tring to get u
bigfatmat1,
Jun 10, 6:04pm
that is ians work no he will be at home now so you will prob not reach him on that no till the morn
bigfatmat1,
Jun 10, 6:07pm
Does your car not go because of the igniter or the coil! I really doubt a igniter will fix your problem of stuffing coils. You are fitting the correct coil not a ballast coil(6v)! who is looking at the car for you! Maybe you have a incorrect diagnossis.
countrykids6,
Jun 10, 6:07pm
cheers ill try him first thing then
countrykids6,
Jun 10, 6:08pm
tapawarea garrage are doing it for me ,
bigfatmat1,
Jun 10, 6:08pm
he is nelson auto parts over the road from harvey norman in st vincent st.
bigfatmat1,
Jun 10, 6:10pm
sounds like a miss diagnosis to me. igniters dont stuff coils. coils stuff igniters.
countrykids6,
Jun 10, 6:11pm
oh thanks u dont happen to have his home phone do u! i think vechile really needs to go to someone with the computer soft ware to plug it into
muzz67,
Jun 10, 6:18pm
Alan Hampton is his name.
countrykids6,
Jun 10, 6:19pm
ill give u the full run down of what exactly the vechile is doing , monday a week ago i left wakefield and headed south towing a horse float and felt vechile was sluggish but thought it was just due to the towing weight , i got to motapeko and engine died free wheeled to a stop , once stopped a gear box fault came up and then tried to restart vechile and it just wound over and sounded as if there was no spark what so ever , then vechile put its self in low 4wd and wouldnt come out ,
then was towed to tappaera gargae where they replaced a burnt out coil and replaced all leads and spark plugs and the engine fuse which had blown .
then saturday morning same thing left wakefield towing a float got to koeroke and the vechile did exactly the same thing as befor so i had a look at the coils and again it had burnt out number 8.and but its self in 4wd low
