How much $$$ to adjust tappets
mitsiboy69, Sep 23, 10:09am
My mitsubishi is doing the typical tick tick ticking so I want to get the tappets adjusted. Does anyone know how much it would cost! It's a 1.6 DOHC 4cyl
johnf_456, Sep 23, 10:12am
Pro-Ma MBL8 say no more.
vtecnet, Sep 23, 10:12am
Just buy some proma mbl8 and add that,.
I assume those cars use Hydraulic Lifters.
mitsiboy69, Sep 23, 10:14am
Nah they are not hydraulic lifters. So I'm pretty sure they need to be adjusted!
richynuts, Sep 23, 10:48am
Change the oil
intrade, Sep 23, 10:54am
what engine! somone can tell you when you tell the engine code and its year. some are shimmed and these are the harder and more expensive ones to adjust as you got to exchange shimms.
mitsiboy69, Sep 23, 11:05am
Wow thanks for the great advice.
It's a 4G92 Mivec and apparently the noise can be greatly reduced with adjustment.
a.woodrow, Sep 23, 11:06am
Changing the oil would be the first thing I'd do
How sure are you that they aren't hydraulic!
intrade, Sep 23, 11:07am
changing the oil wont do anything to tapet noisewhen they need adjusting mechanically . only helps with hydraulic ones and promar only is for hydrolifters cant tell you if they are hydraulic as my autodata is on the computer with currantly no monitor but i am sure you get a answer soon.
mitsiboy69, Sep 23, 11:11am
I am 110% sure they are not hydraulic.
kingfisher21, Sep 23, 11:12am
They are not hydraulic, .1mm for the intakes and .2mm for the exhaust COLD, if you need a shop to do it allow for probably 1-2 hours labour and a rocker cover gasket if needed.
a.woodrow, Sep 23, 11:14am
So you've had the rocker cover off and looked!
intrade, Sep 23, 11:14am
i found a youtube video one guy posted not easy . someone would know i guess you want to know who can do them in wellington correctly!
http://www.youtube.com/watch!v=4SmZmqYh4QE
mitsiboy69, Sep 23, 11:14am
I'm happy to do it myself but don't you need a special tool! I have feeler gauges.
intrade, Sep 23, 11:15am
confirmswhat they written on the youtube clip
intrade, Sep 23, 11:16am
get a manual for it myght be online even if your in luck.
mitsiboy69, Sep 23, 11:18am
haha mine is not that bad yet. Such an ugly noise though!
kingfisher21, Sep 23, 11:19am
Can be fiddly to do, probably better off taking it to a Mitsi dealer. Manual for you,
www.mivec.co.nz/tech/4G9x_Engine_Manual.pdf
mitsiboy69, Sep 23, 11:23am
Yea thought as much, cheers. It will be worth paying for.
intrade, Sep 23, 11:30am
i would make sure you find a good place like whangarei mitsubishi told me when i wanted some shimms for a 4m40 that they dont adjust valves and therefor dont have shimms and wished me luck. You dont want morons like that adjust your valves.
turton, Sep 23, 11:44am
honda quoted me around $200 for adjusting my tappets on my car, so should cost around that
a.woodrow, Sep 23, 11:53am
how are they morons when they told you that they didn't do them and therefor don't carry the shims!
intrade, Sep 23, 11:55am
if they dont adjust valves when it comes in for a service because they just dont bother to. do that part ,,,, i guess you be real pleased if you get your car serviced with em and then one day it stoped with a burnedvalve.
franc123, Sep 23, 1:14pm
It wouldn't be a question of not bothering, more like the customers won't pay for the extra time involved in the course of a service, which according to some people on here shouldn't cost more than $69 inc gst, labour, materials, a wof, groom and the owners bum wiped. If it was an easy half hour job on most cars it would be more likely to be done but when you do daft things like make them shim adjustable instead of thread and locknut like they should be and put intercoolers over the top of the rocker covers it all gets too hard. On newer cars that are on lease plans they won't pay for it either unless the driver moans about noise or rough running.
splinter67, Sep 23, 1:19pm
Yup that will do it not you are the first mechanic Ive seen tell some one to put this in a car great advice LOL
