GOLF . AGAIN. ding ding round 4
ruthd, Sep 17, 2:13pm
ok this is getting silly.
new trans heat converter, car back wednesday, back to garage wednesday needing new water pump due to oil/coolant mix messing with bearings.get the car back on saturday now back in with trans issues!
Sigh.
skin1235, Sep 17, 2:41pm
have you checked the car itself
cos it sounds more like its a rebadged honda or, mitsi than a super reliable, very cheap and easy to fix golf
scoobeey, Sep 17, 2:48pm
LOL .dont worry parts are super cheap ,if you ever need them :)
mantagsi, Sep 17, 2:48pm
I'll give you $100 for it :D but hey, my last golf I owned was technically dead, and some kind chappie paid me $700 for it - if you let yours die too, it might increase the resale value
intrade, Sep 17, 2:52pm
told you the trans is gona crap it self if it gest coolant in and is not flushed imediatly with new filter and all.
i also told you that its not straight forward on the mk4 , morons wont be able to service that it requires speciall filler tools i posted you the website with pictures how its done in your last thread maybe you should print it out and show the morons who are messing with your car.
intrade, Sep 17, 2:56pm
even a reliable toyota trans will crap it self if it gets coolant water gets in the lowest point of the trans and it wont go anywhere till it is removed phisically with dumping the sump of the transmission. A mk4 golf is regarded by morons as not servicable but it is you just need to know how.
ryanm2, Sep 17, 2:57pm
It really does sound like the issue if with your 'mechanic' than the car.
kazbanz, Sep 17, 2:59pm
Ruthhave you returned the car to the dealership every time for repair!
To be honest normally I say give the dealer fair shake of the stick but this time I'm thinking tis time to return the car and get your money back. It does sound like you have a lemon
intrade, Sep 17, 2:59pm
he got some sort of warranty and cant use professionals it seems due to the warranty.
intrade, Sep 17, 3:07pm
yea no one services them they are not less reliable then any other transmission exemptions are some toyota stuff like the ones on corollas mid 90s they can go without service to 350 tousend and then a service and they go another 100,000km You also asked what makes are the secound most common to be repaired ! its mitsubishi ones
intrade, Sep 17, 3:24pm
you dont understand do you vw have got a transmission fluid that is called a lifetime fluid well that is the understanding now livetime is not what it sounds to be , you murder somone and get live is also only 20 years sometimes only 7 . because of this most places wont service the transmission till its making a pooo. If you buy a manual for a vw witch i happen to own. there it says to replace the fluids and how. It is discribed in details , i have posted how on the last thread he made. They never serviced the transmission when the cross contermination of his broken cooling radiator happenedi also told him on the last threadthat exactly what has happend now will happen.
unbeatabull, Sep 17, 6:30pm
Lifetime fluids generally refer to around the 100,000k mark I've found in most cases!
skull, Sep 17, 6:36pm
There's something missing from this VW thread, can't put my finger on it but there's definitely something missing.
kazbanz, Sep 17, 6:44pm
SHHHHHH. -no theres not.it won't apear as its a real life documented failure
gammelvind, Sep 17, 6:51pm
But but how can it be they are just so reliable!
trdbzr, Sep 17, 6:54pm
And parts for them are so cheap that they make the $2 shop stuff look expensive.
compchick, Sep 17, 9:06pm
Apparently if you look into a mirror and say its name three times it appears. ooorrr maybe that's the Candyman, either way both are quite scary one will take your soul the other will take over your thread.
nzdoug, Sep 17, 11:32pm
Your talking original beetle
ruthd, Sep 18, 12:02pm
UPDATE . It's not the trans its the spark plugs! phew.1 and 4 are misfiring.policy approved garage quotes $441.continental cars $112.go figure!
trdbzr, Sep 18, 12:05pm
And now Jazz is going to feel safe coming into this thread.
intrade, Sep 18, 12:06pm
continental cars will just charge you 112$ and fix nothing. a client took them to court when his tdi blew up cam belt replacment was only charged for never done on the vehicle. go figure ,,,,,, that one you only ever go to gilltrap if you want the job done right not cheap but they got all work on record years after still . I rang gilltrap to ask on a few items of my tdi because it was not fully discribed what they done and they told me straight away every serviced item its all in there computer log like professional mains dealers should be.
ruthd, Sep 18, 12:06pm
i officially hate this car.I don't hate things but this car!yep. hate!
ruthd, Sep 18, 12:07pm
so they are dodgy too then!auto clinic have quoted 195 still way off the other garage!441 is taking the mic
jmma, Sep 18, 12:09pm
Call it Tiger, he stuffed his golf (o:
intrade, Sep 18, 12:10pm
Go to Gilltrap or Qualität if you can use them i am 100% sure you can use gilltrap with a warranty they are the most professional main dealer for VW
