Where to buy linch pins?
trade4us2, Jan 20, 1:15pm
The linch pins I have seen have a gap between the pin and the spring when it's closed on one side.
I want no gap on either side!
mechnificent, Jan 20, 1:20pm
Tractor shops have them, or outdoor equipment.
NZTools, Jan 20, 1:21pm
Any tractor dealership rural garage or agricultural supply store such as CRT or RD1 stocks them
NZTools, Jan 20, 1:33pm
The ring has been put on the pin the wrong way round.
Put the pin in a vice and pull the ring off. Turn it round 180 degrees and put it back on.
mechnificent, Jan 20, 1:34pm
That's a really bad one Trader, they aren't normally that bad, not new ones.
And. I think that linch pins is a bit of an old fashioned expression. I wouldn't be surprised if you got more help at the shops if you ask if they have clevis pins. I know the difference, but I think that a lot don't.
mechnificent, Jan 20, 1:35pm
Yeah, or tweak it.
trade4us2, Jan 20, 1:41pm
Well I never heard of them until a few days ago. That one is brand new and had a label on it saying it was a linch pin. All the others are the same.
I know that it should be put on the other way around, but in the dark and when wearing leather gauntlet gloves, it needs to be easy to put on.
I'd rather have an R clip, but the ones I have seen are far too strong to put on by hand or too piddly and thin.
snoopy221, Jan 20, 1:45pm
pop the wordslinch pin
In that search bar up above.
trade4us2, Jan 20, 1:45pm
Maybe I could take the pin off and throw it away, and make a new pin that is at right angles to the spring.
trade4us2, Jan 20, 1:47pm
Of course I've done that. I wouln't mind a long drive to some farmer's supplier in the country if I was sure they had what I am asking for. But I bet they won't have it, so I'll have to make something, as usual.
NZTools, Jan 20, 1:50pm
I think you missed what i was getting at. Remove the ring completely off the pin, turn it round and put it back on again so it closes properly with no gap. It has simply been assembled wrong.
snoopy221, Jan 20, 1:53pm
mmkay well then
The difference between
Heavy Duty
and made in chinkawalla.
Is quite CLEAR to you now if you actually went in to the auctions the search provides.
trade4us2, Jan 20, 2:17pm
OK I just tried that. There is no difference except that the gap is now on the other side.
To recap, I want a pin up to 6mm in diameter that can go in a hole and not fall out. It does not have to be heavy duty - it's just to stop a ring sliding off the end of a handle. It must be easy to put on without tools and while wearing thick leather gloves.
jmma, Jan 20, 2:25pm
Not sure what they are called, they are usually keyring type things, that has a threaded thing you spin back, then its a push spring loaded clip (o:
kat.irons, Jan 20, 2:26pm
What you need to do is rotate the ring over the top to close on other side, as they are only designed to close on one side
ola_bitchola1, Jan 20, 3:30pm
as someone has said couldnt you use a clevis pin and retainer ! or maybe a snapper pin is more what you could be after have seen those at tractor places ect
trade4us2, Jan 20, 3:41pm
Karabiners! No, they are too hard to clip on according to the person using it with leather gloves on.
tigger8, Jan 20, 3:44pm
ripco, supacheepetc etc
trade4us2, Jan 20, 3:47pm
Yes they would work but slow to put on. Really I want something that can be clipped in using one hand wearing a big thick leather glove.
NZTools, Jan 20, 3:54pm
What you have is about as good as you will get. Just getsome good quality ones.
trade4us2, Jan 20, 6:17pm
Thankyou, I think I have bought a couple of things from them already.
I'll go there and check out their linch pins.
Otherwise I could drill a new hole in the right place in the linch pin that I have.
illusion_, Jan 20, 6:19pm
no need to drill a new hole
just bend the ring so it's off-centre. the vice and hammer method
pig-gal, Jan 20, 6:22pm
Replies 18 & 19 are right, looking at the photo the spring is on the wrong side. If you look closely at the picture in the Wikipedia link you'll see how it should be. No dismantling required, just flip the spring right over the pin.
http://en.wikipedia.org/wiki/Linchpin
illusion_, Jan 20, 6:31pm
well bugga me . it is too
snoopy221, Jan 20, 6:45pm
Well someone had ta ask
What IS the application that means one can not simply remove the leather gloves and undo it!
