Blown head gasket?
Page 3 / 3
snoopy221, Aug 13, 7:07am
Anyways all good back in the old thermosiphon 12 horsepower respectively but modern engines have radiator caps for a reason or 3 and some of those reasons are actually ADVANCED physics
mojo49, Aug 13, 7:20am
My 1934 Morris 8 had a pressurised cooling system but my 1952 Ford Prefect was thermo-siphon with no water pump. Had a huge radiator but never overheated. Never towed with it of course. My parents has one previous to me. My mother packed a whole lot of pots and pans in front of the radiator so we could get all the gear in to go camping once. My father drove the 52 Prefect like that from west Auckland to Raglan and it did not overheat. Hopefully the OP will get a good outcome and get his old banger past the 500Km mark. Not a bad achievement with a jappa. Maybe jazz could advise him on his next purchase?
snoopy221, Aug 13, 7:25am
yep but insert the nineties and fuel consumption lightweight high strength steel crumple zones thermostat controlling water intake to engine temperature as light highly stressed aluminium heads that steam pocket and need pressure for cooling surface area and can not be thermal shocked.
Hell 1952 ford prefect would handle a year of thermal shocking in a boat with cold salt water cooling average modern engine would last all of 5 minutes.
mojo49, Aug 13, 7:31am
All too true. I wonder what I did with the special valve guide removal tool I had for the 52 Prefect. It would be a collectors item now and an essential tool for any current proud 1952 Ford Prefect owner. The valve guides were split in two. You compressed the valve spring, took out the locator, removed the spring, lifted the valve and put the tool around it, hit it with a hammer and out fell the valve guides. All too easy! I barely even lift the bonnet on any car newer than mid 90s. Just a maze of technology now. I stick to playing with computers. They are simpler!
snoopy221, Aug 13, 7:41am
muwaaaahhhhaaaaaaaaaa
what like an L300 with a top hose thermostat that ya can do ya demon vacuum valve tricks on not like a 96 camry with a bottom hose thermostat
lol
Ya gotta love windows ten aye especially the day ya think ya'll just slave the laptop drive and transfer some files over quick and easy and the damn thang has a permisssion issue and loses it's MBR and voila damn lets juss P around and rebuild a new install and suss that damn issue out
LOL
mojo49, Aug 13, 7:46am
Now you know why I stick to Win 7 Ultimate. I have a DVD with unlimited licences (ask no questions). Hated Win 8 and 8.1. Had a play with Win 10 and have since downgraded newer laptops back to Win 7 Ult. They run great and just require a bit of research to get all the correct drivers. Bit like the L300 really!
snoopy221, Aug 13, 7:50am
Yeah well me i simply have adapted and changed with the times but yeah first time i have had that issue with win ten and will NEVER have it again -LOL
bluecambridge, Aug 13, 8:00am
You guys crack me up! Thanks for all the entertaining discussions and anecdotes, made my day
tamarillo, Aug 14, 4:55am
Hold it. Question was about confirming if its got a Blown head gasket not how to run with it. How do you know the thing has? Surely test first and cure later.
mojo49, Aug 14, 5:01am
Nah. Real blokes just keep fixing each symptom as it crops up until they have spent more than it would have cost to diagnose and fix the actual problem in the first place. Then they sell the car and claim she's running sweet as bro1
bluecambridge, Aug 14, 8:42pm
I'm pretty sure the water loss and black sludgy deposit on the radiator cap is a clear indicator of a blown head gasket It must be a small leak though, as it still starts & runs fine It's been like it for a while too. My mechanic keeps replacing the radiator cap so compression must be leaking into the cooling system. Also it blows coolant into the over flow bottle so seems like it's definitely being pressurized by engine compression (I only have a minor grasp of the theory involved)
marte, Aug 15, 4:06am
Yeah that was my point too.
Both of my last 'Blown headgasket' car buys (I have a spare engine) have not been blown headgasket'.
One cost $12 to fix. And a mechanic said " it has a blown headgasket'". New water pump belt.
And the other, a replacement Oil cooler. = Free as I had one already.
Just a whole bunch of coolant changes & mucking out mucky tan clay like oil from the overflow tank. + Used oil/filter swap out & future brand new oil & filter & G12++ coolant = $110 (?)
marte, Aug 15, 4:08am
OP. Has it got a oil cooler?
Has it been checked for cylinder pressures &/or cylinder gases in the coolant?
Is there water under the oil?
snoopy221, Aug 15, 4:26am
Meh zee ole coupla thousand pressure of a combustiing engine beating a 13 PS I rad cap.
[Ya dunnae need------a physics degree (and if I did, I wouldn't swing it around like a limp dick at a swingers party),]
Edited by bluecambridge at 10:43 am, Tue 14 Aug
Quote
bluecambridge (201 201 positive feedback) 10:42 am, Tue 14 Aug #61
bluecambridge, Aug 15, 5:45am
marte - it has an oil cooler for the trans but for the engine I don't think so. Water under the oil? I don't think so looks to be just plain old oil on the dipstick. Not sure if my mechanic has done a pressure test etc but he did seem to think there was a small leak across the head gasket. symptoms certainly seem to point to that eh snoopy221?
mojo49, Aug 15, 5:50am
I think you will find that when water gets into the sump it sort of gets emulsified with the oil and the mxiture goes a milky brown colour. I have never seen an engine with water under the oil on a dipstick, except for the engine in a mates boat, which sank on its mooring. In that case it seemed to be overfull of oil.
mojo49, Aug 15, 5:54am
Even if I did not have a physics degree I would agree with you, subject of course to doing a proper pressure test on the cooling system. Plus trying the old method of taking the radiator cap off, bringing the engine up to operating temperature and looking to see if any little bubbles are appearing at the top of the radiator. It is not as good a test as the sealed system pressure test but it is a good indicator that something is amiss.
bluecambridge, Aug 15, 6:15am
mojo49 - the oil hasn't gone milky, no tell-tale milky deposits on the oil filler cap. Seems like compression is leaking into the cooling system but the coolant is not leaking into the cylinders. My mechanic thought it might be a very small leak that opens up as the engine gets hot
mojo49, Aug 15, 6:22am
That means it could have a blown head gasket with just a small leak between a cylinder and a cooling system duct. No water would get into the oil in those circumstances. Even so, the issue is for you to stop the loss of coolant for a realistic cost. Using the new product snoopy suggests looks like the best place to start, irrespective or whether it is a head gasket or cracked head issue.
bluecambridge, Aug 15, 6:30am
exactly right mojo49, and that is how I intend to proceed this weekend!
marte, Oct 27, 5:01am
Oil coolers between the housing on the block for the oil filter, and the oil filter.
It will have two medium size hoses on it & is a obvious seperate part.
Oh, oil pressure beats water pressure when cold, even when hot.
Yep, sounds like it's head gasket by the posts just above.
