DODGY WOF inspectors
Page 1 / 3
bobinnz, Oct 30, 11:29pm
Just failed a WOF on worn brake pads and shoes! Purchased new shoes and pads and went to fit and there is almost NO WEAR on the old ones! What recourse do I have? Feel absolutely ripped of! Only plus is he did not get the work or parts!
intrade, Oct 30, 11:56pm
yea did you check both front and rear?
i know this can be the case.
A sales rep told me he does not get why they run radio-Adds that they only check wof.able items.
I said its probably to say we dont try and get extra work like others.
muppet_slayer, Oct 31, 12:13am
Normal first course of action would be to actually check the linings first before purchasing new ones.
hazelnut2, Oct 31, 12:15am
Go back and try to pass again, with the old ones cleaned up? If you pass, report the mechanic to an appropriate authority. Good luck!
tygertung, Oct 31, 12:15am
Just keep the old ones for next WOF fail, put the old ones back in.
hazelnut2, Oct 31, 12:16am
Why? I would be trusting the mechanic who told me the old ones were worn.
muppet_slayer, Oct 31, 2:19am
So that this sort of thing does not happen in the first place.
muppet_slayer, Oct 31, 2:36am
There is no way they could have done a proper inspection of the brake linings. I would not trust them.
curlcrown, Oct 31, 4:36am
What did the reject sheet actually say? You can't see brake shoes to fail them on wear but only on performance. Is there a warning light on the dash giving a false reading?
lythande1, Oct 31, 4:47am
VTNZ did that to me once, went home, husband took it apart and checked, Zero wear, put it back together, took car back for recheck himself, and oh look, it passed.
cattleshed, Oct 31, 7:04am
Again, what does the WOF sheet actually say because they can not see shoe lining wear. You can have new pads and shoes and yet poor performance so send through details on WOF sheet and make and model.
redhead18, Oct 31, 7:55am
23. Brake friction material (where visible without removing vehicle components) (Note 2) is:
a) worn below manufacturer’s specifications, or
b) separating from the brake pad backing plate or brake shoe, or
c) contaminated by brake fluid, oil or grease.
End of the day no 4 disc pads will EVER wear the same and the thinnest IS the weak link that when you NEED to stop can overheat the resin bonding and become steel on steel.
So FAIL.
And we await the make year and model to acess the MANUFACTERERS minimum thickness.
Refer prior post Number 14
Edited by redhead18 at 2:27 pm, Sun 11 Oct
Quote
redhead18 (1090 1090 positive feedback) 2:23 pm, Sun 11 Oct #41
Nissan navara 2008
Quote
bobinnz (612 612 positive feedback) 2:35 pm, Sun 11 Oct #42
Measurements were at the thinnest friction material on the 4 pads!
Quote
bobinnz (612 612 positive feedback) 2:37 pm, Sun 11 Oct #43
Have you spoken to the WOF inspector about it? You could ask another inspector for his opinion. Have the pads been removed for replacement?
Quote
curlcrown (559 559 positive feedback) 2:58 pm, Sun 11 Oct #44
Probably these
https://www.bendix.co.nz/shape/db1835
Factory 17 millimetre so 50%=8.5 75%= 4.25 Most manufacturers ONLY allow 70%
(And utes are hard on brakes)
Reality is Inspector is only doing his/her job in failing
Edited by redhead18 at 3:17 pm, Sun 11 Oct
Quote
redhead18 (1090 1090 positive feedback) 3:17 pm, Sun 11 Oct #45
bobinnz, Oct 31, 6:49pm
How do I upload photos so people can see for themselves?
kateley, Oct 31, 6:54pm
I once was failed by vtnz because my airbag indicator light wasn't working - I was really worried about the expense of getting something like that fixed until the toyota repair centre told me that my car didn't have an airbag indicator light !
bobinnz, Oct 31, 6:56pm
Just taken off the back drums and shoes have minimal wear 2-4mm wear not 2-4mm left no oil leaks. Saw him remove inspection grommet on rear brakes and look inat inspection! Is this normal?
bobinnz, Oct 31, 7:29pm
thepiercedkiwi, Oct 31, 7:44pm
I have had the same issue with VTNZ. They said I needed a letter from who put in the brake pads with a letter head on to pass. I decided just to get the workshop to do my WOFS from now on.
tgray, Oct 31, 8:12pm
Go back and talk to them.
bobinnz, Oct 31, 8:21pm
No way
gazzat22, Oct 31, 8:41pm
Presumably it was a local garage that you dealt with.I would go to a testing station,show them the WOF check sheet and see what they say.They probably wont charge you and if its not correct will have a "talk" to the garage.
sandypheet, Oct 31, 10:07pm
gazzat22 wrote:
Presumably it was a local garage that you dealt with.I would go to a testing station,show them the WOF check sheet and see what they say.They probably wont charge you and if its not correct will have a "talk" to the garage. [/quote.Have you not been to a testing station lately. Why would you ask for opinion when as a rule testing stations tend to get bagged anyway. Go speak to the owner/manager of the garage and sort it.
gazzat22, Oct 31, 10:28pm
Yes I went to a testing Station about 2 months ago for a WOF and found as I have in the past they go by the book and dont try to sell you something you dont need unlike some garages. And FYI i have never "Bagged" a Testing Station. The poster indicated fairly clearly they did not wish to go back to the place that failed their car so a Testing station to me is the logical and independent place to go to.!
franc123, Oct 31, 11:49pm
It's actually a requirement that they do so where inspection ports are fitted.
bobinnz, Nov 1, 12:32am
Now maybe you understand my anger! One car failed because of faded lenses-acceptable and fixed. One car stolen and abused to hell, told $100 to tow then charged $500! My truck failed wof pads and shoes "worn" when I went to replace them after purchasing new shoes and pads($200) Shoes and pads are more than 50% of the new ones! Yes I am pissed!
bobinnz, Nov 1, 12:35am
What do you think https://www.facebook.com/photo/?fbid=10224323973148429&s
et=pcb.10224323975628491
If I go back I may not be as polite and calm!
