I have a retractable seatbelt stuck. It's in the middle of the back seat in a Ford Mondeo SW, is there a way to get to the mechanism and unjam it!
a.woodrow,
Nov 21, 6:22pm
Make sure the seats are locked fully back as this can sometimes cause seatbelts to jam
ralphdog1,
Nov 21, 6:53pm
It will not go in or not go out or both!
exwesty,
Nov 21, 7:30pm
It's locked and can't be pulled out.
ml6989,
Nov 21, 7:45pm
x2
I have been caught with this problem in a Mondeo and this was the answer
Nov 22, 7:53am
exwesty--is the car sitting on a slope! that can lock the belt up
richard198,
Nov 22, 8:06am
If none of the above work, remove the reel so you can tip it and maybe release it. If that doesn't work, then you have the reel out for dismantling.
marte,
Nov 22, 2:10pm
Make sure the things level & then pull the belt, or move it around a little while grabbing the belt. Next thing is, get a source of compressed air & blow it around & into the mechanism.
Don't take it apart unless you have given up on it.
exwesty,
Apr 2, 1:19pm
Seat was locked back ok.
Have wiggled, jiggled the belt and finally got it to release.
Warrent time.
