Hi i need to change the driver side, Am i looking at a simple job!
fragmented5,
Jan 2, 11:00am
Got our local garage to quote on this job, $500. Couldn't believe it :(
blackdotlova,
Jan 2, 11:09am
na won't be doing that, i've got some spanners i'vehad for a few years just have to blow dust off. Just asking if i have to worry about air bags!
treachug,
Jan 2, 11:33am
Not connected to the airbags. Just be careful with the interior trim - take your time removing the trim & look where the clips are etc to save breaking them.
blackdotlova,
Jan 2, 1:33pm
Cheers people, the last time i made a living with spanners hq holdens where new
peasgood,
Jan 2, 1:57pm
Would that model not have pretensioners!,dont they work with the srs!just curious!
treachug,
Jan 2, 2:14pm
Assuming the OP is replacing the webbing belt part mounted on the outer not the pretensioner mounted on the tunnel there is no percieved issue.
Jan 2, 2:18pm
Yes, it has a pretensioner. No big deal.
unbeatabull,
Jan 2, 2:23pm
As mentioned, make sure you get all the trim off and all the clips etc. I think they used Torx bolt to hold the bottom part in which your spanners won't be able to undo, and have a feeling the screws holding trim on are either philips or T-20 Torx
blackdotlova,
Aug 4, 12:40pm
Thanks unbeatabull i have torx bits, I,m like a magpie with tool and have added some over the years when i see bright shiny bit and bobs
