Need info on how to set up the balance shafts and chain on Mazda G6 engine. 1992 Mazda B2600 Ute.
budgel,
Nov 30, 9:23am
It is actually a Mitsubishi Astron engine I believe. Look for an online manual. Even if you cant get the exact manual, you may be able to work it out from general setup. This link is to a diesel motor, have a look to see if the engine block is similar. They use a guide plate with marks on it to st the shafts up.
Thanks Budgel but this is a Mazda G6 not the Mitsi Shiti 4G54 engine that the earlier mazda's used.
jaydeesnr,
Apr 20, 3:09am
l found a site with full engine specsand diagrams by searching the ford courier/ranger connection. lt covered all the engines including G6. l may still have some downloaded specs with the site name on them at work ,Will look tomorrow and keep you posted. Cheers
