Help with ea
Page 1 / 3
johdoe, Jan 24, 5:35am
can sombody tell me why my flywheel wont turn i have just put in a new motor an now it wont
move. its all bolted up.
modie61, Jan 24, 5:36am
Auto or manual !
johdoe, Jan 24, 5:37am
auto
modie61, Jan 24, 5:38am
Possibly the torque converter is not in the box all the way.
Anyone else !
johdoe, Jan 24, 5:39am
how can you tell its all bolted up
modie61, Jan 24, 5:41am
Loosen all bellhousing bolts without removing them,then try turning the motor.
If it turns over thats what it will be.
You will have to remove motor again to relocate torque converter into auto correctly.
johdoe, Jan 24, 5:52am
lol gee thanks dont realy wont to do that agen but if i have to then i have to. how will i know its in correct
jash3, Jan 24, 4:29pm
Hi mate was the motor out of an auto or was it a manual! cause if it was a manual thiers a spigot bearing that needs to be removed first.
unbeatabull, Jan 24, 4:33pm
Also, if it was a Manual, the Flywheel will have to have been replaced by a Flexi Plate
unbeatabull, Jan 24, 4:34pm
Torque Converter will still turn on those old 4 speeds (I assume its a 4 speed) will just get no drive!
johdoe, Jan 24, 6:37pm
ea 3 speed auto
sounds like it could be out of a manual had it out agen today torque converter all fine just when all the bolts are dun up it wont turn
unbeatabull, Jan 24, 6:40pm
Has it got a flexi plate on it rather then a flywheel!
johdoe, Jan 24, 6:43pm
its got a flywheel its just when u tighen up the bolts it all locks up
unbeatabull, Jan 24, 6:54pm
If it's an auto you need a Flexi Plate . a Flywheel will not work. The Torque Converter acts as a flywheel amongst other things
johdoe, Jan 24, 6:58pm
its a straight swap one out one in
jmma, Jan 24, 6:59pm
Hang on a minute, he is not just calling the flexi plate a flywheel is he! OP are you bolting the torque convertor to this so called flywheel!
unbeatabull, Jan 24, 6:59pm
You can not mate a Auto Trans up to a Fly wheel. It won't work. Plain as simple
unbeatabull, Jan 24, 7:00pm
He did say the engine was originally out of a manual.
johdoe, Jan 24, 7:05pm
no i said it could be out of a manual
so the flywheel must be what u call a flexi plate im bolting it to the torque convertor sorry
unbeatabull, Jan 24, 7:07pm
So four bolt holes! From memory you do them up from the Starter motor hole, don't think the EA's had the cut out at the bottom to do them up.
Is the trans still in the car or out!
johdoe, Jan 24, 7:09pm
will the torque convertor turn free before the motor is bolted to it eazy as
johdoe, Jan 24, 7:10pm
ea yea got the cut out bottom trans still in car 4 bolts
unbeatabull, Jan 24, 7:11pm
Silly question, do you have all the gear linkages etc connected and car in Park/Neutral! Can you push the car back and forwards! (I assume trans is still in car and Driveshaft etc bolted up)
johdoe, Jan 24, 7:14pm
yea hard to push in neutral with motor out an now in havent touched trans just unbolted it
