Central locking issue
jezz43, Apr 23, 7:08am
VT commy, drivers door has had lock replaced in the past. when i use the keyless entry the door doesnt unlock all the way sometimes, the lock goes about 3/4 of the way up and stops. all the other doors work fine. ive opened the door and checked for bent rods but its all fine. anything else i could check! could the central locking unit not be actuating properly!
lookoutas, Apr 23, 7:17am
Lubrication!
And does it work OK with the door trim off!
jezz43, Apr 23, 7:23am
ive CRCd all moving parts. its exactly the same with or without the trim.
budgel, Apr 23, 7:50am
Measure the operating stroke of the unit in one of your good doors and compare with the driver's door.
jezz43, Apr 23, 8:30am
just checked it out, and it appears to be the same as passengers door.
fordcrzy, Apr 23, 11:16am
motor may be worn out. it works but doesnt have the correct torque
demons, Apr 23, 11:22am
mine did same thing make sure the button is in it tracks
jezz43, Dec 1, 11:43pm
dont this also. it doesnt do it all the time, so im beginning to think it may be the locking unit is on its way out
